Resistors connected to op-amps
NewbieEngineer
Joined Oct 30, 2022
Hello everyone! I'm trying to solve this assignment and I'm not sure what to do with all those resistors. Should I calculate an equivalent resistance for each group? And how do the resistors connected between the terminals of the op-amps influence the circuit?
Ian0
Joined Aug 7, 2020
13,311
There are four resistors which have no voltage across them, so you can ignore them.
There are four more resistors where the current through them has no effect on the operation of the circuit. You can ignore them as well.
That only leaves three that you have to deal with.
38,932
No, you can't solve for the equivalent resistance to solve the problem.
Do you understand the characteristics of an ideal op-amp and how it works with negative feedback?
If not, then first read a tutorial on that.
35,281
Firstly, consider the impedance of a source driving a load.
In general, you want the impedance of the source to be lower than 1/10 that of the load. In this way, the effect of the load is less than 10% on the source.
Assuming that the impedance of Vi is much lower than Ri, you can ignore Ri.
Similarly, the output impedance of an ideal op-amp is 0Ω. For this reason, ignore R4, R9, and R10.
Ian0
Joined Aug 7, 2020
13,311
WHat is the voltage between the inputs of the op-amp when the feedback is operating correctly?
So how much current flows in the resistors?
How will that current affect the rest of the circuit?
35,281
Two rules apply when working with ideal op-amps.
1) No current flows in the input pins.
2) The inputs must be at the same voltage otherwise the output will saturate to +infinity or -infinity.
How did I arrive at this?
Here are the properties of an ideal op-amp:
1) The input impedance is infinite.
2) The output impedance is zero.
3) The voltage gain is infinite.
4) The bandwidth is infinite.
WBahn
Joined Mar 31, 2012
33,326
Let's give the TS an opportunity to apply the numerous hints they've already been given and to show their best attempt to work the problem.
I wonder if the two hidden 'gotchas' in the circuit were intentional, but let's let them come out in due course.
