0.05 ohmsView attachment 125657 I know this should be easy one for you guys, but not for me
I don't know if I'm reading this resistor value correctly, is it a 50 Mega Ohm ? Or 50 Ohm ?
Thanks, so it's 50 milliohms ?0.05 ohms
Looks that way to me. Do you own an ohm meter? Measure it. The resistance is so low it will probably read as zero (or a few tenths of an ohm in your test leads) because most meters can't measure that low.Thanks, so it's 50 milliohms ?
By using the wrong meter you have introduced an AC component. The reading of 28 milliohms says the resistor is outside its tolerance range, but the resistor looks perfectly OK from the outside. Please use a real ohm meter or just assume that a very low resistance reading means the resistor is good.
