Resistor identification assistance please..
Eostre
Joined Dec 8, 2023
Hello, looking for assistance, I am used to identifying resistors by the colour code.
I have a pair without colour code, these were soldered though hole in a power supply PCB for a Bang and Olufsen television. The PCB is about 8 years old and the failure seems to be commonplace at this age.
Whilst burnt these meter at 9.5M Ohm, 9mm in length, 3mm in diameter.
Markings seem to be A139.9, I could be wrong about the A1as the two letters are joined. Maybe even an R and the dot (.) could be a burn mark! I attach an image, hoping someone can identify these.
Thank you in advance.
35,200
Maybe it is 9.9M.
There appears to be a space between the 3 and the 9.
9.9 is an unusual valve, why did't they just call it 10.
ericgibbs
Joined Jan 29, 2010
21,585
Hi Eostre,
Looking at the resistor construction, I don't believe they are 9.9Mega Ohm.
Use an ohm meter to measure the least looking damaged resistor.
E
Eostre
Joined Dec 8, 2023
Hi Eostre,
E
Thank you Eric, I metered them both at 9.5Mega Ohm. I found some on Mouser physical size being similar, going to try when these arrive.
