VarResistor “upgrade”?
robismod
Joined Sep 22, 2015
473
I have an electronic HiHat cymbal on my electronic drum set. It has the top single cymbal that rides up and down on a long rod in a stand, controlled by a foot pedal linked to the rod. Beneath that rubber cymbal is a plastic “base” that has a variable resistor mounted inside it. That resistor is controlled by a small plastic link that is attached to a moving plunger—when the foot pedal is pushed down the top cymbal moves up and away from the “base”…that plunger is within a spring so as the top cymbal moves up it allows the plunger to come up and the amount it moves the VarResistor changes the sound of the HiHat from a closed sound to an open sound…
My problem is that difference is erratic and difficult to get correct sounds at the right moments. (The whole drum set triggers drum software on a laptop)
I’m adding pics to show it, and how small it is…I’m wondering if there is a way to improve it the tracking of it? I don’t think I’ve ever seen a variable resistor like this one…
35,279
Measure the resistance of the pot, across the two outside pins.
Then, measure the variable resistance over the full range of the pedal. While exercising the pedal, see if there are any inconsistencies in the resistance. There could be some damage in the resistance track.
B-JoJo-S
Joined Jan 3, 2026
599
My Hi-Hat has a touch of inconsistency too. And it's brand new. How long have you had yours? Was it always like that or is this a new development? What brand is your set? Mine is Roland. I've never disassembled anything; largely because it's new. I'm still learning how to adjust the Hi-Hat on my set. I'm not always satisfied with the sensitivity.
robismod
Joined Sep 22, 2015
473
All of that tests fine…although I’m not quite sure, where the link “travel” starts and a reading shows, if that’s the exact spot that is the very bottom of the pedal travel…otherwise, it seems a smooth range by the numbers…
robismod
Joined Sep 22, 2015
473
It’s a Donner, and about a year or so ago I had bought their top-of-the-line—at that point—DED-500 kit. A couple months ago they offered the pedal stand kit for an unreal 118 bucks so I bought one.
But I didn’t use the Donner module at first—opting to stay with my old trusty Roland TD-6V module, and triggering the EZDrummer3 software. The original hi-hat cymbal worked just ok so I thought this new one would be a nice improvement. But so far the main sticking point has been the very bottom pedal position—not giving me consistent CLOSED sound, as if I’m letting up on the pedal pressure. Donner’s tech team has been very helpful to me in the past and as well this time. They’re trying to help me figure it out. A Google pic search came up with ideas of bad solder joints in the little board causing the intermittent sounds. However I ran across another YouTube video that dived into a simple possibility of a simple rubber washer added to the top of the plunger, to make the assembly go deeper, hoping to get to the point on the VR where it would stay consistent…
Hope that helps a little…
35,279
I am asking for actual numbers.
What is the resistance of the pot?
What is the resistance at minimum and maximum range of the pedal?
I am considering what alternatives there are to the pot.
robismod
Joined Sep 22, 2015
473
On the top and bottom contacts I get a solid 10.35k ohms and on the first and second points, on the low end I get 7.9 ohms, and it runs upwards to 10.35k ohms with the movement of the linkage arm…
schmitt trigger
Joined Jul 12, 2010
2,276
If a unit is brand new and is already misbehaving, I would immediately contact the factory. Roland is a reputable company, or at least it has been for three decades, so they should correct the issue.
robismod
Joined Sep 22, 2015
473
Latest: I added a shim to the plunger unit that links to the VR…it didn’t fix it, maybe slightly better. It seems as if the glitches are a happening because the VR doesn’t have the tight quality needed for the precise cymbal sounds: pedal pushed down for fully closed sound and as pedal pressure is released gradually cymbal should gradually go from closed sound to fully open sound.
I’ve been trying to find a similar replacement but not having much luck weeding through so many search results…
The previous arrangement was a cymbal mounted solidly on a stand, and a pedal that used a flat strip to change the resistance by varying the pedal resistance.
this new version is supposed to be the most realistic but I’m feeling the simple VR is the weak point. (Pics of it posted earlier)
I’ll continue trying to find a similar piece…
