Resistor Detection Circuit
28,450
What I did not see is how accurately the setup needs to be, how close to 470K ohms does the resistance need to be for the LED to light. A circuit that might be more useful than a bridge would be a window-comparator using two sections of a LM339 comparator. as mentioned in post #13.
ConnaTC
Joined Jun 20, 2020
18
Thanks for your reply
I’m going to try a couple of circuit including the window comparator to see what works best, In regards with tolerance i know the ohms can fluctuate depending on resistance from the wire connected to the socket i need to do more tests with a multimeter to determine this factor.
Does a window comparator need to be precise at 470knor can it fluctuate?
KMoffett
Joined Dec 19, 2007
2,918
In post #13 I included two trim pots to set the upper and lower acceptable limits. So any resistance between these is OK. Circuits are out there to do that.
35,245
Bad logic.
The resistance you are attempting to detect is nominally 470kΩ.
If you allow for:
±10% variation, that would be ± 50kΩ
±5% variation, that would be ± 25kΩ
±1% variation, that would be ± 5kΩ
The resistance of connecting wires is very unlikely to exceed 10Ω.
Any variation you measure is going to reflect the tolerance of the resistor itself.
You can set the lower and upper limits of a window comparator to whatever you desire, for example, 440kΩ to 500kΩ.
Still easier to go buy a DMM.
28,450
A DMM req1uires an operator to have the skill to set the switch to the correct function, and to be able to read and understand the numbers and then evaluate that reading relative to some limits.
The reality is that there are a whole lot of people who can not do that on a consistent basis. That is why every production testing machine that I ever designed had a red light and a green light, for accept and reject. And that was a lot of machines for quite a few different companies over the years. Some of them also displayed numbers, but always RedLight/Greenlight.
ConnaTC
Joined Jun 20, 2020
18
I do use a DMM on a daily on the field just wondering if a circuit could be made to give illuminated feedback as I’ve only used a handful of IC’s which i come on here for opinions and advice.
28,450
A system can be made that evaluates the signal from a digital meter and delivers an accept or reject output. I did one of those for checking that all of the fuel injectors were connected on an engine harness for a big auto company. That circuit was sort of complicated and I don't even thing the company that made the digital meter is around today.
BUT there are digital multimeters that interface with a computer, and it should be simple enough to have a simple program compare the measured value with the programmed limits. And it may be that the meter companies like Fluke or Beckman already have such a product that includes the Pass/fail limits system. Certainly this is not the only time such a function has been needed.
ericgibbs
Joined Jan 29, 2010
21,601
hi,
I would have thought a guy who uses a DMM as part of his field servicing anyway, should know how to read the resistance value from a DMM.?
E
KMoffett
Joined Dec 19, 2007
2,918
Minimum components in my opinion would be a Picaxe08M microcontroller, two resistors (470KΩ and 270Ω), an LED, a battery, a push-button switch, and a telephone plug. Well a cord and a case too. Simple to program with free programing software. A Picaxe would also require a USB-to-Serial cable.
28,450
hi,
E
I am presuming that the setup would be for use by somebody less skilled in the use of a meter. That is usually why semi-automated equipment is used.
Tonyr1084
Joined Sep 24, 2015
9,744
Something not mentioned (or asked) is: Assume three states (and for sake of discussion assume absolute perfection of values)
State 1: Open circuit.
State 2: 470KΩ.
State 3: zero ohms.
I point this out because I'm wondering exactly what it is you want to test for. Can you find different resistances in your test such as 330KΩ or 610KΩ (or other)? Wire lengths will affect resistance to some extent. Long runs will have higher resistances. And as already mentioned, resistors can have varied accuracy. Precision resistors are ±1% whereas common resistors can be ±20%.
If you're looking for any of those three states then the solution can be even easier.
KMoffett
Joined Dec 19, 2007
2,918
Microcontroller can handle all three ranges too. But at anything ranging outside of 470KΩ(+/-tolerance) needs intervention...I assume.
ConnTC, you still haven't been forth coming in what context this will be used and by whom.
ConnaTC
Joined Jun 20, 2020
18
If i can detect all 3 ranges that be great As far I'm aware the resistors aren’t precision,
The circuit will be used by New field engineers whom don’t get supplied with DMM or other devices with Multimeter functions
Tonyr1084
Joined Sep 24, 2015
9,744
So you're saying you need to detect a short, open or 470KΩ resistance?
Where is the 470KΩ resistance coming from? Is this something someone inserts into the circuit for testing?
