Resistor Detection Circuit
ConnaTC
Joined Jun 20, 2020
18
Hi Guys I’m looking to build a circuit which will light an led when it detects an 420k resistor will i require a transistor circuit for this to work?
If this post is in the wrong section I apologise i am a new user?
ericgibbs
Joined Jan 29, 2010
21,567
hi C,
So a Bridge, made up of say one 420K and the other half of the bridge say 10k's, a AD623 INA [ OPA] driving a transistor LED or Buzzer, powered from say a 9V battery could work.
Make the circuit detect a Zero balance .
E
Update:
Is it always going to be 420K, also what resistance tolerance is acceptable.?
ConnaTC
Joined Jun 20, 2020
18
That could work il have to look into AD623 to make something up
hi C,
E
Update:
ConnaTC
Joined Jun 20, 2020
18
Many apologies i got the resistor value wrong its 470k not 420k in regards to your question it should always be 470K so the tolerance can fluctuate quite a bit if needed
hi C,
Check out my update , post #8, there maybe a cheaper , simpler way.
E
KMoffett
Joined Dec 19, 2007
2,918
For a Go/NoGo circuit a 470k half bridge and a window comparator with adjustable upper and lower trim pots. No need to read and think. ;)
ericgibbs
Joined Jan 29, 2010
21,567
hi C,
As the 'Accept on Test' resistor value is always 470k , I would go with post #12.
A DMM test meter is a useful piece of kit to have in your toolbox for other tests you may have to do.
E
Dodgydave
Joined Jun 22, 2012
11,395
BT phone sockets have a 1.8uF cap between pins 2,3 and a 470K resistor between pins 3, 5. .
..best solution is a DVM as posted earlier...
