required : sallen key filter unity gain model for PSpice
KFUPMer
Joined Nov 4, 2015
8
Hi guys ,
I am trying here to design 4th order Lowpass Chebyshev filter
and the given data :
1/3dB Frequency: fo= 3KHz
2/Pass Band Ripple = 1dB
I have used this sites to design my filter :
(http://www.daycounter.com/Filters/Sallen-Key-LP-Calculator.phtml)
as u can see I have used unity gain
If R= 2.5K Ω , then c1= 54.62nF and C2=11.1nF (The first stage)
The second stage should be identical to the first stage .
the circuit :
#Problems:
1/after this long introduction , I want to simulate this circuit by using PSpice but I do not have a model for sallen key filter unity gain
2/ Should the gain be exactly =1 in the simulation ???
MikeML
5,444
What prevents you from just entering the component topology, the resistor and capacitor values, and a suitable opamp model into PSpice?
Cascading two identical filter stages does not produce the correct 4th order response.
Go to the MicroChip website and download FilterLab. It synthesizes active filters from specs, and will handle the two cascaded stages correctly....
Here's what FilterLab comes up with:
KFUPMer
Joined Nov 4, 2015
8
So , they should not be identical ???
and this is my SPice file :
Code:
project
Vs 8 0 AC 1 sin(0 1 1k)
R1 7 8 2500
R2 7 2 2500
R3 1 9 2500
R4 9 5 2500
C1 1 7 54.62n
C2 2 0 11.1n
C3 4 9 54.62n
C4 5 0 11.1n
X1 2 1 1 OPAMP1
X2 5 4 4 OPAMP1
.SUBCKT OPAMP1
(what should I write here ?????)
.ENDS
.AC dec 100 10 40meg
.TRAN 0.01m 2m
.PROBE
.END
KFUPMer
Joined Nov 4, 2015
8
one last question , how can I enter the value of (Pass Band Ripple) in FilterLab ????
KFUPMer
Joined Nov 4, 2015
8
Filter/Design/FilterSpecs/...
Check all of the parameters that can be specified.
sorry mike for my stupid question but there is nothing called Pass band ripple , but I found ( PassBand Attenuation its range from -3 to -1 ) and (StopBand Attenuation its range from -10 to -100)
