Required help with LTC3265
Akash Singh
Joined Apr 19, 2017
10
Hi there!
I need to get +15v and -15V from a 12V source. LTC3265 appeared to be a promising solution
But now during testing, I'm getting 15V on the positive side but only -1.3v on the negative output.
Please help in suggesting a trobleshooter.
Akash
bertus
Joined Apr 5, 2008
22,922
How much current are you drawing from the chip?
The datasheet shows a max of 50 mA:
Did you use the schematic for the typical application?
Bertus
Akash Singh
Joined Apr 19, 2017
10
Yes @bertus, the same circuit.
And regarding the current, I haven't yet connected the load. I was just testing my circuit.
But it will be used to drive a sensor, with not more than 20mA input current.
bertus
Joined Apr 5, 2008
22,922
Wich package of the chip do you use?
As you can see Pin 19 on the left picture and pin 21 on the right picture are the ground connections on the bottom of the chip.
Do you have that connection made?
Bertus
Akash Singh
Joined Apr 19, 2017
10
Bertus
I'm using the TSSOP package, and yes the ground pins and the plane are perfectly soldered.
Also, I've used electrolytic capacitors instead of ceramic ones, does that make a difference?
Only the Inverting voltage side of the circuit is not working properly.
bertus
Joined Apr 5, 2008
22,922
What is the voltage on the Vout- pin (pin 9 of the tssop)?
I would expect something like 22.5 Volts.
Bertus
bertus
Joined Apr 5, 2008
22,922
I assume you have the connection between Vout+ and Vin-N (pins 20 and 13).
Then You should measure the +24 Volts also on pin 13.
If so check Cinv between pin 10 and 12.
Bertus
Akash Singh
Joined Apr 19, 2017
10
Bertus
The voltage at pin 10 is -1.2V and at pin 12 is 10.63V(with ref to gnd).
But across the Cinv capacitor, the voltage is 13.38V. I don't understand why should there be a difference?
bertus
Joined Apr 5, 2008
22,922
The voltage accross the Cinv is an AC signal of about 500 kHz.
The AC is created by an oscillator and the switches in the inverter circuit:
In the first stage S5 and S6 are closed, S7 and S8 are open, the Capacitor is being charged.
Then S5 and S6 will open, S7 and S8 will be closed, so the Capacitor is connected to Vout-.
This is the way how it sould work.
When the Capacitor is bad, the inverter can not work.
Bertus
Akash Singh
Joined Apr 19, 2017
10
Bertus
So it is a bad Cinv capacitor you're saying?
bertus
Joined Apr 5, 2008
22,922
The capacitor could be bad.
The + of the capacitor should be on pin 12 and the - of the capacitors on pin 10.
Bertus
Akash Singh
Joined Apr 19, 2017
10
Bertus
Yeah, the cap was bad. Thanks for helping in troubleshooting :)
Output voltage levels are now 14.8V and -13.8V.
Will have to do some tuning now. Any suggestions? o_O
bertus
Joined Apr 5, 2008
22,922
The voltage dividers will adjust the voltage.
It may be that the voltage references are off, but still in spec.
Also tollerances of the resistors will come into play.
Bertus
bertus
Joined Apr 5, 2008
22,922
There are two LDO regulators inside the LTC3265.
One for the positive voltage and one for the negative voltage.
In the full schematic you will find the resistors in this part:
The datasheet will show the calulatons for these resistors.
Bertus
