narkeleptk
- Joined Mar 11, 2019
- 558
These types of fuse box terminals I see a lot. Two in front of me right now actually. I usually just sand them down clean, flux the hell out of it then use hot air and a iron with knife tip wedge full blast to tin it with solder. After its all done I sand it smooth .Looks brand new again. i will do the same with some of the pins when they are heavily oxidized. If it needs more material I'll use copper sheets/tape or even solder wick in a pinch.@shortbus, I would love to be able to just replace these terminals but as you can see from the pictures, it may not be that easy. Very hard to find the source of such pieces as you must know coming from Delphi and the secret compilations of OEM proprietary data. I need to coat the large terminal and sometimes replace some of the smaller terminals around it due to corrosion. I usually steal them from another board.
