This is from a project I'm working on. A user can choose between DPDT functionality (so having "SensorI" be a motor that goes forward and reverse) or add another sensor in place of the first sensor having DPDT functionality. The DPDT requires two +VccRelays.
So the relays on the left can be effectively thought of as simply Vcc. This is my current design. It works. (I implemented and tested it.)
Although, I want the user have less switches to screw up. So I figure there's a way to replace the two switches on the right (SW2 & SW4). Do you think this will work:
I tried to make it easier to understand where the switch labels have corresponding letters (where A matches everywhere with A, and B with B). If doing switch B, then the DPDT is enabled.
