Replacing Operators
ElectricSpidey
Joined Dec 2, 2017
3,357
Is it possible to replace an operator with a variable in C++?
In other words instead of…
++ Foo;
Could I use…
int var = ++;
Then…
var Foo;
ElectricSpidey
Joined Dec 2, 2017
3,357
Because... :p
I need to change a PWM value to a new value using a loop (step), but I wont know whether I need to increment or decrement the value until its ready to change, so I was hoping I could change the operator as needed after determining the direction.
WBahn
Joined Mar 31, 2012
33,094
Because... :p
Even if you could do what you want, what has it bought you? Once you know the direction you would still need to change the code and recompile.
There are languages where you can do this, such as lisp.
Why not just do something like:
int step = 0;
// Code to set step to some value such as +1 or -1
Foo += step;
Another way would be
// Code to set dir to 0 for decrement, nonzero to increment
dir? Foo++ : Foo--;
AlbertHall
Joined Jun 4, 2014
12,640
Because... :p
You could set var to either plus or minus 1, then do 'foo + var' which will either increment or decrement foo.
IMO purely from a structured programming viewpoint your desired capability seems to Obfuscate instead of Clarify the intent of the code and as others have said here there are much better ways to express what you want without the possible runtime hit needed to decode variable capabilities beyond memory operation requirements.
WBahn
Joined Mar 31, 2012
33,094
So the bottom line is, changing a operator on the fly is a big no-no.
It depends.
This is almost always a correct answer to any engineering-related question.
You can't do it like you are describing in C++. There are languages where you can. Those languages tend to suffer from poor runtime performance because of all the extra overhead associated with doing what you are trying to do.
Whether it is a big no-no depends entirely on what is important to you.
You haven't given a hint as to what is important to you and what you might be willing to trade to achieve it, so the best we can do is tell you that it depends.
ElectricSpidey
Joined Dec 2, 2017
3,357
When it comes to coding what is important to me is...doing the job and keeping it simple. I'm not married to any particular way of doing something but with my lack of experience it can take quite a long time to come up with any method, so I need to find out issue by issue which ones work and which ones wont.
And I thank you all.
35,072
That's what we're for.
Don't be afraid to ask.
