I have 24 volt 15a power supply that I'm trying to replace the power transistors. they are D13009k(NPN bipolar power transistor) rated 400v 12a.
I found a MJW221196 NPN POWER Tranny rated @ 250v 16a and a MJH6283 rated @ 80v 20a. Can I use these 2 to replace thecD13009k NPN rated at 400v 12a???
i also found some MJH6287 but there PNP . The ones that blew were NPn . Can I i use them instead in my cheap 24v 15a power supply. I'm thinking NO
and if the D13009k that I'm trying to replace are only rated @ 12a, then my power supply is not rated 15a as it's described then huh? so if those npn trannys are rated at 12 amps that's Max current I'm assuming correct? that would explain why I blew it up
