I am trying to replace the battery in a battery operated motor with a direct AC source. So far i think i need to use an AC to DC power supply, but im not sure about the current/wattage specs. The battery specs are (Li-Po 37 V - 2.5 Ah - 92.5 Wh battery) and when i look at the manual for the product it lists the battery charger at (100 VAC - 240 VAC / 50 - 60 Hz / 42 VDC - 2A battery charger). The part that confuses me is the average motor power is 189 watts. So what should my system look like if i wanted to replace the battery with AC power, and what should be the specs for the power supply? I can answer some questions if needed.
