Replacing burnt resistor from Polar 72 Cutter
Xavier Pacheco Paulino
Joined Oct 21, 2015
728
See picture attached. As you can see, there is an useless resistor, which is open, and a gray capacitor, 0.25uF/630V, which also suffered. I replaced the gray capacitor with the red one 0.22uF/630V. The resistor burned so bad that I had to make a hole to remove the burned area. The resistor value cannot be seen. I'm trying to guess what value it could be. I will try to draw an schematic to figure out its purpose. All I can see is that the capacitor and the resistor are in series. Any help in identifying the resistor is appreciated.
MaxHeadRoom
Joined Jul 18, 2013
30,807
If a snubber, seems rather large for a cube relay, although it is across coil also, but only the coil as a load?
Is this relay continuously operating many times/min?
Max.
Joined Oct 21, 2015
728
Max.
I'm actually not sure. It's from a cutter that it's not mine. I haven't operated it. The board has other connections. I will try to gather more info.
