We are a public company, we cant buy on e-bay or similar sites. We really need to replace with something that we can buy in local market.Hello,
You could look on ebay or some old stock sellers:
https://www.ebay.com/sch/i.html?_fr...C0.H0.X6514+sram.TRS0&_nkw=6514+sram&_sacat=0
https://www.digchip.com/datasheets/parts/datasheet/235/HM-6514.php
Bertus
If you cant purchase from non compliant source you need to discard/scrap the appliance.We are a public company, we cant buy on e-bay or similar sites. We really need to replace with something that we can buy in local market.
Thanks.
What does being a public company have to do with buying off e-bay or similar sites? With a part that old, you're going to have a difficult time finding a replacement. I agree with @takao21203 in that you will have to scrap your appliance and find a modern equivalent. Now that is efficient use of public funds.We are a public company, we cant buy on e-bay or similar sites.
Then why are you here? Why aren't you using your local market sources?We really need to replace with something that we can buy in local market.
Sometimes with SRAM - you can just use a higher capacity part and pull up (or down) any unused address lines.Hi, I am a maintenace supervisor in São Paulo subway, we need to replace an old 6514 SRAM, we have serious troubles to buy this obsolets chips.
Can someone help us with some circuit to replace a bank of this chips?
Eng. Valdir Gomes
That's of ram... bank of ramReplacing banks for ram is not so hard. But you have to know (at least) the size you are replacing (how many bits x how many k).
Thanks, I will use this solution, I'm in a process of selection to not chose another obsolete memory.Sometimes with SRAM - you can just use a higher capacity part and pull up (or down) any unused address lines.
A board full of them probably entails ripping them all out and patching in a single SRAM chip with at least as much capacity as the whole board.
You might locate original parts from a NOS broker, but they usually only entertain large orders - and aren't known for being cheap.
That means you need to redesign anything that uses obsolete parts.as a public company we need three diferents supliers to chosse the best price, this three companys have to submit proposes so we can choose the supplier.
AFAIK; SRAM is getting harder to come by, the 0.6" form factor started getting thin on the ground. 0.3" SRAM chips were very popular for a while for cache/scratchpad memory on older PC motherboards. They're probably easy to find among newer SE Asia silicon foundries.Thanks, I will use this solution, I'm in a process of selection to not chose another obsolete memory.
Just to clarify, as a public company we need three diferents supliers to chosse the best price, this three companys have to submit proposes so we can choose the supplier.
Eng. Valdir Gomes
