Replacement 74ls123
tymenot
Joined Jul 1, 2024
10
Hello
I wonder where is the A1 B1 and A2 B2 in this circuit
And I need explain is it rising edge trigger or what
panic mode
Joined Oct 10, 2011
5,301
i assume you saw a1 b1 etc in the datasheet such as:
pins 8 and 16 are power for two identical units.
first unit has inputs pins A1, B1 etc. (pins 1 and 2)
second unit has input pins A2, B2 etc. (pins 9 and 10)
the schematics you posted has first unit marked as U26A and the second as U26B.
also inverter at input A1 is not shown as a separate gate but part of AND gate (See the circle on one of inputs).
Note both representations are the same thing (same IC) so there is no need for substitution
tymenot
Joined Jul 1, 2024
10
What does your post have to do with the title of this thread?
Yes you are true Sir
No link between the title and the question
Here is th link about it
I do have Mc14538 and I want to know where is the AB/1-2 of the 74ls123 and how it's triggered (in the schematic )in order to replace 74ls123 with MC14538
I know that it's less pulse width about 10 us that's enough for my demand and need
Both mc14538 and 74ls123 not pins compatibles
I find hard understanding AB in both
Even in schematic I provided I don't know where is AB
Thanks for your response
tymenot
Joined Jul 1, 2024
10
Thanks for your explanation yes I saw the datasheet but what tricked me the MC14538 when I try to use it in the schematic the circle pointed to B not A
35,210
74x123 has /A AND B input.
A must be LOW and B must be HIGH to trigger the circuit.
In other words,
falling edge of A while B is HIGH
or rising edge of B while A is LOW.
MC14528/14538 has A OR /B input.
The circuit is triggered on
a rising edge of A while B is HIGH
or a falling edge of B while A is LOW.
tymenot
Joined Jul 1, 2024
10
In other words,
Thanks a lot for you
But in simple words if you please in the schematic is it triggered rising or falling triggering
And in simple words gain regardless the values of RX CX how to to use MC14538 to work in place of 74ls123 in schematic I provided in the same manner
Thanks in advance
panic mode
Joined Oct 10, 2011
5,301
you need to decide which input is to be edge sensitive. then keep the other input in suitable state.
as MrChips already stated:
In other words,
tymenot
Joined Jul 1, 2024
10
So is my understanding now correct or not
to replace 74X123 with MC14538 in same schematic I need to connect ... A1 to trigger source... B1 to vdd ...rest to vdd same as the other part A2 B2 rest is that true or I am mistake
panic mode
Joined Oct 10, 2011
5,301
not sure what you are trying to do and why. 74LS123 is active, normally stocked and easy to find product, for example
https://www.mouser.ca/c/?q=74ls123
if you are trying to replace IC on an already made board, this substitution makes no sense (it will be a challenge) since MC14538 is not pin compatible with it. if you are creating new board design and trying to substitute IC before board is made, this could work assuming you check the specs (supply level, logic levels, output fanout, pinouts...).
the way 74LS123 is connected, the AND gate and inverting input (A) are simply bypassed. timer works as if B connects directly to trigger. so doing the same on MC14538 would require bypassing input B, and using input A as trigger.
in other words, going from one IC to another:
1. swap A and B inputs (use B instead of A and use A instead of B)
2. bypass inverted input so that it does not interfere with triggering. on LS123 this was done by connecting B to GND (input A is trigger). on MC14538 this is done by connecting A to Vcc and using B as trigger.
Tip:
when in doubt, always give yourself a plan B (an easy way out). this could be adding jumpers or DIP switches or solder-jumpers so that you can determine and apply correct connection later - after board is made. i am often pressed with time to release design to meet deadlines while many new features are added. so i do just that, add in my designs things that can alter circuit behavior without mess of piggybacking things or wires criss-crossing PCB. this allows me to salvage protoboards and deliver things on time which would be impossible with time wasted on on reordering.
tymenot
Joined Jul 1, 2024
10
Tip:
when in doubt, always give yourself a plan B (an easy way out). this could be adding jumpers or DIP switches or solder-jumpers so that you can determine and apply correct connection later - after board is made. i am often pressed with time to release design to meet deadlines while many new features are added. so i du just that, add in my designs things that can alter circuit behavior without mess of piggybacking things or wires criss-crossing PCB. this allows me to salvage protoboards and deliver things on time which would be impossible with time wasted on on reordering.
Thanks for you and for all
The reason I want to Use the MC 14538 in place 74x123 is that I do have about 1000 chips
Now I understand the logic of both ...no it's not replace of working device I am going to design timing stuff
Once again thanks for you
Thanks for all
tymenot
Joined Jul 1, 2024
10
Final answer to this topic
In this schematic using 74123 with same configuration with MC 13538 the result is inverted result of 74123 due (rising/falling trigger) for each chip
Thanks for all
panic mode
Joined Oct 10, 2011
5,301
i do not know what you mean.
the two pictured cases show same IC (74LS123A) but using different input as trigger. response of both cases is the same. they just react to a different trigger edge as was already discussed.
tymenot
Joined Jul 1, 2024
10
Here is what I mean both chips If configured as the previous 74123 configuration theyScreenshot_2025-08-22-04-38-29-868.jpeg going to give opposite rising / falling logic
35,210
We don't understand what you are saying.
With either IC, you can trigger it however you want, with a rising edge or with a falling edge.
Which one do you want?
tymenot
Joined Jul 1, 2024
10
I am saying both has opposite logic and i found how to trigger as I want
Here's the trigger logic for both
Thanks for all
