To detect a trickling leak? I don't think so.Just use a microphone mounted on the pipe. QED.
Only problem with that approach is that it would be affected by changes in temperature. One could use a thermometer, of course. But temperature wouldn't be constant throughout a long pipe.I know it works for gas, Not sure if it works for water. Used to do it all the time for vacuum leaks. But anyway, you can look at pressure drop over time. I just don;t know what the sensitivity has to be. Even if water is incompressable, there would be air I the pipe, that would obey PV=nRT. Change in Volume from 0. n,R and T are constants. Anyway, you let air out of a tire, the pressure goes down. You let air into a closed pipe, the pressure goes down.
If you close off a segment of water that's at constant temperature. Measure the pressure and measure it sometime later, it can be due to temperature or a leak. Not sure what resolution you need.
Hopefully little air is present.I know it works for gas, Not sure if it works for water. Used to do it all the time for vacuum leaks. But anyway, you can look at pressure drop over time. I just don;t know what the sensitivity has to be. Even if water is incompressable, there would be air I the pipe, that would obey PV=nRT. Change in Volume from 0. n,R and T are constants. Anyway, you let air out of a tire, the pressure goes down. You let air into a closed pipe, the pressure goes down.
Yes, unless it's intentionally part of the system. My pressure tank in my basement has an air bladder. The well pump runs when the pressure in the tank is less than 50 psi (just a guess) and stops when it hits 55 psi (another guess). That would happen almost immediately if the air wasn't there, since water in incompressible as you know. I can detect a "leak" in my system when I hear the well pump cycling late at night.Hopefully little air is present.
Most homes have water pressure of about 35 to 40 psi... 50-55 psi would make for a very enjoyable power shower!Yes, unless it's intentionally part of the system. My pressure tank in my basement has an air bladder. The well pump runs when the pressure in the tank is less than 50 psi (just a guess) and stops when it hits 55 psi (another guess). That would happen almost immediately if the air wasn't there, since water in incompressible as you know. I can detect a "leak" in my system when I hear the well pump cycling late at night.
Then turn up the regulator next to your meter. I'm running 50 psi. The local water utility provides 75 psi to the regulator.Most homes have water pressure of about 35 to 40 psi... 50-55 psi would make for a very enjoyable power shower!
65 PSI here.Most homes have water pressure of about 35 to 40 psi.
I don't have a regulator. My Reverse Osmosis system has an incoming pressure gauge and an outgoing pressure gauge. My incoming fluctuates between around 60 and 68 PSI. I've seen homes as high as 80 PSI and even 100 is not unheard of. But that's rare. 50 would be the low end of what I've seen in my lifetime that I know of.Then turn up the regulator next to your meter.
Gosh, I just learned something new! ... down here water pressure is much lower, and I see no need for it to be any higher, at least for domestic applications. And no, we normally don't have water pressure regulators at home either.65 PSI here.
If that device is truly measuring the pipe diameter, an assumption I’m not ready to accept, it would respond to pressure in the pipe and to temperature changes. Neither is perfectly correlated to a small flow.Hi there! I saw this thread, did you find solution however ?
I saw some interesting things other guys do,
I think they use smth with Strain Gauge ( like in regular weight scales ) by measuring expansion of tube
I am curious if small amount of water ( or even drops ) could affect tube expansion what we could measure with strain gauge ( resistance difference )
I agree and enter the problem. Unless the pressure in a line is enough to get something from a strain gauge I don't see it working. As shown it looks to be maybe a 3/4" or 1.0" copper pipe and I would think you could have plenty of flow before the pipe would expand enough to be measurable. It does look interesting though, whatever it is.If that device is truly measuring the pipe diameter, an assumption I’m not ready to accept, it would respond to pressure in the pipe and to temperature changes. Neither is perfectly correlated to a small flow.
