Hi J and T,Current and temperature of MCU is ok?
Hi T,Programming currents and voltages are too small to make sizzling sound on PCB.
If supply is from PICKIT then there are all of the loads which are connected to 3.3V regulators.You can during programming use PCB power supply or make supply from PICkit but not in same time.
Hi J and T,If supply is from PICKIT then there are all of the loads which are connected to 3.3V regulators.
PICkit can supply only about 30mA.
Is your 3.3V reg up and PICkit Vdd output off ( selected off in the program) when flashing the chips?Hi J and T,
It normally programs ok.
Pickit3 is powered externally.
Note: With all this sizzling and errors, I'm ordering some more 18LF4620. At £6 each, I had better get a safer system!
C
Hi J,Is your 3.3V reg up and PICkit Vdd output off ( selected off in the program) when flashing the chips?
Why do you have then connection from programmers Vdd to 3.3VHi J,
Yes, it's off in the programmer, and if I try to program without the PCB voltage ON, then it errors and lets me know.
C
Hi J,Why do you have then connection from programmers Vdd to 3.3V
My badHi J,
Isn't that how it should be wired?
How do you think it should be wired?
C
Hi J,My bad.
My bad
I was confused that the Vdd on Pickit is output only and could by accident be on at the same time as the Vdd on PCB.
Hi T,MPLAB programmer usually warns if PICkit power delivery is activated. If high voltage programming is in use then voltage sensitive components connected to MCLR must be temporarily disconnected. Look at the poster which comes with the PICkit3.
