Remote control by location (PIC in Oshonsoft)
camerart
Joined Feb 25, 2013
3,853
There are still some glitches to sort out with the peripherals, which we'll work on as we go.
Next try spinning a motor with the REMOTE. For this SERVO motor control is needed.
Can someone scan these 3x examples of CODE and recommend which would is best for me to start with please?
The bottom one was kindly written by 'E'
C.
Code:
2.3.8 Using internal PWM modules
Internal PWM modules (more precisely: PWM modes of CCP modules) are turned on using
PWMON statement.
This statement has two arguments.
The first argument is module number and it must be a constant in the range 1-3.
The second argument is used for mode selection.
Internal PWM module can be used on three different output frequencies
for each of four duty cycle resolutions supported by PWMON statement (10-bit, 9-bit, 8-bit and 7-
bit).
So, PWM module can be turned on with PWMON statement in 12 modes.
Here is the list of all modes at 4MHz clock frequency
(for other clock frequencies, the values should be proportionally adjusted):
mode 1: 10-bit, 244Hz
mode 2: 10-bit, 977Hz
mode 3: 10-bit, 3906Hz
mode 4: 9-bit, 488Hz
mode 5: 9-bit, 1953Hz
mode 6: 9-bit, 7813Hz
mode 7: 8-bit, 977Hz
mode 8: 8-bit, 3906Hz
40
mode 9: 8-bit, 15625Hz
mode 10: 7-bit, 1953Hz
mode 11: 7-bit, 7813Hz
mode 12: 7-bit, 31250Hz
The PWM module is initially started with 0 duty cycle,
so the output will stay low until the duty cycle is changed.
PWM module can be turned off with PWMOFF statement.
It has only one argument - module number.
The duty cycle of PWM signal can be changed with PWMDUTY statement.
Its first argument is module number.
The second argument is duty cycle and it can be a constant in the range 0-1023 or byte
or word data type variable.
User must take care to use the proper value ranges for all PWM modes (0-1023 for 10-bit
resolution,
0-511 for 9-bit resolution, 0-255 for 8-bit resolution and 0-127 for 7-bit resolution).
Here is one example example:
DIM duty AS BYTE
PWMON 1, 9
loop:
ADCIN 0, duty
PWMDUTY 1, duty
GOTO loop
Code:
2.3.9 Interfacing Radio Control (R/C) servos.
For writing applications to interface R/C servos there are two statements available
SERVOIN and SERVOOUT.
R/C servo is controlled by a train of pulses (15-20 pulses per second)
whose length define the position of the servo arm.
The valid length of pulses is in the range 1-2ms.
These two statements have two arguments.
The first argument of both statements is the microcontroller pin where the servo
signal is received or transmitted.
41
For SERVOIN statement that pin should be previously setup as an input pin
and for SERVOOUT statement the pin should be setup for output.
The second argument of SERVOIN statement must be a Byte variable where the length
of the pulse will be saved.
The pulses are measured in 10us units, so it is possible to measure pulses in the
range 0.01-2.55ms.
The value stored in the variable for normal servos should be in the range 100-200.
The second argument of the SERVOOUT statement should be a Byte variable or constant
that determines the length of the generated pulse.
For proper operation of the target servo SERVOOUT statement should be executed
15-20 times during one second.
Here is an example of the servo reverse operation:
DIM length AS BYTE
TRISB.0 = 1
TRISB.1 = 0
loop:
SERVOIN PORTB.0, length
IF length < 100 THEN length = 100
IF length > 200 THEN length = 200
length = length - 100
length = 100 - length
length = length + 100
SERVOOUT PORTB.1, length
GOTO loop
Code:
'18F2431 RX DATA to PWM 160218 1200
fine CONFIG1L = 0x00
Define CONFIG1H = 0x02
Define CONFIG2L = 0x0e
Define CONFIG2H = 0x20
Define CONFIG3L = 0x18  'PWMPIN outputs active on RESET
Define CONFIG3H = 0x80
Define CONFIG4L = 0x80
Define CONFIG4H = 0x00
Define CONFIG5L = 0x0f
Define CONFIG5H = 0xc0
Define CONFIG6L = 0x0f
Define CONFIG6H = 0xe0
Define CONFIG7L = 0x0f
Define CONFIG7H = 0x40
'Connect to PC UART, 9600 Baud
'PORTA.0 n/u
'PORTA.1 =
'PORTA.2
'PORTA.3
'PORTA.4
'PORTA.5
'PORTA.6
'PORTA.7
Define SIMULATION_WAITMS_VALUE = 1  'else 0 for PIC
'PORTC.0 n/u
'PORTC.1
'PORTC.2
'PORTC.3 n/u
'PORTC.4
'PORTC.5
'PORTC.6 n/u
'PORTC.7 n/u
AllDigital
ADCON0 = %00000000  'A_D
ADCON1 = %00000000
ADCON2 = %10000000
ADCON3 = %00000000
ADCHS = %00000000  'A_D
ANSEL0 = %00000000  'A_D
OSCCON = %01110010  'internal 8Mhz clock
OSCTUNE = %00000000  'Oscillator tuning register for EUSART
'PCPWM MODULE SEE AN899 PAGE 5 ALSO SECTION 22.0 D/S
'PWMCON0 = %01010100
PWMCON0 = %01000100  'ptmod    '%01010100 turns them all
PWMCON1 = %00000000
DTCON = %00000000  'Power control
FLTCONFIG = %00000000
OVDCOND = %00000000
OVDCONS = %00000000
PTPERL = 0xff  'register
PTPERH = 0xff  'register
PTMRL = %00000000
PTMRH = %00000000
PTCON0 = %00000000  'ptckps'
PTCON1 = %00000000  'PTEN
IPR3 = %00000000  'TMR
PTMRL = %0000000
PTMRH = %0000000
TRISA = %00000000
TRISB = %00000000
TRISC = %00000000
'assign PWM pins
PWMon 1, 8  'RC1 CCP1, Mode at 8MHz at 7812Hz, to change this look at the Manual Tables
PWMon 2, 8  'RC2 CCP2
DFLTCON = 0
PWMduty 1, 0
PWMduty 2, 0
Hseropen 9600
verify_uart:
Hserout "PWM", CrLf
WaitMs 200
Enable High
Dim duty1 As Byte
Dim x As Word
x = 0
'pwm0 And   pwm1   are   controlled   by   the   PDC0H:PDC0L
'PWM2  and  PWM3  are controlled  by  PDC1H:PDC1L
main:
duty1 = 128
If x <= 10 Then Gosub fwd
If x >= 10 Then Gosub rev
x = x + 1
If x = 20 Then x = 0
Goto main
End
fwd:
ASM:        bcf CCP2CON,DC2B0
ASM:        bcf ccp2con,dc2b1
ASM:        movlw 0x00
ASM:        movwf ccpr2l
PWMduty 1, duty1
Return
rev:
ASM:        bcf CCP1CON,DC1B0
ASM:        bcf ccp1con,dc1b1
ASM:        movlw 0x00
ASM:        movwf ccpr1l
PWMduty 2, duty1
Return
On High Interrupt
Save System
Resume
camerart
Joined Feb 25, 2013
3,853
As there are no suggestions:
I have chosen the first method as example '2' to in #1221 uses simple % ON/OFF, and '3' only has '1' output (I think).
EDIT: It looks as though I can't use any of the suggestions in #1221, 1 and 3 both use the CCP of the PIC where there are only 2x. I need 5x.
C
camerart
Joined Feb 25, 2013
3,853
Years ago E Gibbs plus others did a lot work getting Nokia 5110 screens to work with this project. These kept failing due to Zebra strip problems, so I shelved them and sent monitoring messages via UART. As there are now many of them flying about they are clashing, and causing problems, so I now have to get the screen working again.
The 5110 screens, may be a little small, so I will look into the larger screens available. I only need text, and touch screen is not necessary.
If anybody has experience with 'say' 2.2" or similar SPI screens, please let me know.
C
camerart
Joined Feb 25, 2013
3,853
I don't have experience on this, but it seems to be quite popular.
SSD 1306 0.96" oled display.
https://www.ebay.com/itm/255283295122
https://simple-circuit.com/pic18f46k22-ssd1306-oled-spi-mode-ccs-c/
Hi J,
Hi J,
I think the ones I have Nokia 5110 are the best bet, as they have been programmed with SPI unlike the ones you posted which are I2C. I need to get them to be more reliable though, then later I'll look into larger ones, over 2" long.
Thanks, C
camerart
Joined Feb 25, 2013
3,853
I'm integrating 2x programs into 1x.
1/ has an INCLUDE
2/ has 2x INCLUDES
Both work separately, with all 3x INCLUDES in the same folder, but I'm now getting this error as I integrate.
Any ideas?
C
camerart
Joined Feb 25, 2013
3,853
hi C,
Do the 3 Includes have Unique names, and what are they.
E
Hi E,
"fontsml.bas"
"Main MCU config.bas"
"Perpherals setup.bas"
EDIT: I'm integrating fontsml.bas into the FULL program, and in the FULL program, if I comment out fontsml.bas, it compiles.
EDIT-EDIT: I added both programs into one, and commented out the 5110 section, that needs the 'fontsml.bas' and as I slowly uncomment the 5110, it looks like this will show me where the error lies. I'll let you know
C
ericgibbs
Joined Jan 29, 2010
21,569
hi C,
Do you have two commands/operations in the Includes with the same name.?
Also, have you tried the Includes in the Main program, in a different order?
E
camerart
Joined Feb 25, 2013
3,853
hi C,
E
Hi E,
I'm pretty sure you're correct.
One program is from 5 years ago, and one recent, Lots of things have changed, including PCB tracks.
You can see the combinations, like a needle in a haystack.
C
'* 5110 SCREEN set up *
'Symbol lcd_reset = LATC.0 'LATC.1 'LCD_RESET PIN 0=Reset
Symbol lcd_datacommand = LATC.1 'LATC.0 '1=DATA, 0=COMMAND
'Symbol lcd_cs = LATD.0 'LATD.4 '5110 LCD C/S
Symbol lcd_cs = LATC.2 'LATD.4 '5110 LCD C/S
Symbol lcd_rst = LATC.0 '5110 LCD_RST
'Symbol lcd_dc = LATC.1 '5110 LCD_DC
'Symbol lcd_cs = LATC.2 '5110 LCD_CS
camerart
Joined Feb 25, 2013
3,853
I've cornered the the problem to the SPI settings.
The 2017 program was written with Oshonsoft SPI settings and the recent FULL program was written with SSPBUF exchange, so no SPIPREPARE, SPICSON etc.
C
camerart
Joined Feb 25, 2013
3,853
I'm now trying to get the BASE and REMOTE to talk to each other.
So far I've got each to respond to a transmitted MACRO simulating each other, which is woking.
One of the last problems was the TX/RX was getting confused as there were to many to cope with. Now there is a 5110 screen to possible get the signals to only BASE to REMOTE and reverse.
It's quite complicated chaning the programs to reflect messages while PARSING, the sense out of them, and I've just thought of a possible problem.
Here is the TX from BASE: Hserout "$BORI", ",", #ud, ",", #rot, ",", #fr, ",", #lr, ",", strcmd, ",", strprs, ",", strspr, ",", strqeideg, ",", "W", CrLf
It can be seen that there are some VARIABLES starting with # and some with STR. I now think that the # ones are maybe not STRINGS, where the STR ones are STRINGS.
Does this make a difference? Should I convert all #VARIABLES to STRINGS before TXing?
C
ericgibbs
Joined Jan 29, 2010
21,569
hi C.
Usually the $ prefix's an ASCII String and the # prefix's a numeric value, which can be in either ASCII or some other numeric format.
Your message appears to have extra ',' Comma characters, before the parameter value, which are normally used in a CSV type message as parameter separators.??
BTW: I assume the double quotes are for just typing out the message string.???
"$BORI", "," , #ud, "," , #rot,
E
$BORI,#ud,#ror ..................
camerart
Joined Feb 25, 2013
3,853
hi C.
E
Hi E,
The message must be in the same format as the GPS NMEA STRING, i,e, $X,X,X,----,W, so an exact length with each VASIABLE separated by a ',' asyou say CSV. The VARIABLES are PARSED out at the receiving end.
My question is: I've been using both #VARIABLE and STR (=STRING) VARIABLE, does it matter, or do they all need to be STRINGS to be useful?
C
ericgibbs
Joined Jan 29, 2010
21,569
Hi C,
I don't know what you mean by useful.???
Who or what is creating the message is setting either the $ or # prefix and the Data Type.
E
camerart
Joined Feb 25, 2013
3,853
Hi C,
E
Hi E,
The HSEROUT message is sent between BASE and REMOTE to control things or for information, i,e, battery voltage. My term USEFUL means being able to be used at the RECEIVING end to 'say' control something.
I have to match the GPS message format, for PARSING, which looks like $NAME, XXX, XXXXX, XX,W, so I add a $ at the beginning and a W at the end of my messages.
C
ericgibbs
Joined Jan 29, 2010
21,569
Hi C,
Those parameters can be used if the sending end, is sending Valid data from whatever the sending device type is.?
You will have to determine the Data Type from the documentation of the sender device/unit.
For example, what is the Data Type and Format, of the device sending #rot. ???
E
camerart
Joined Feb 25, 2013
3,853
Hi C,
E
Hi E,
From the $BORI in #1234: The first 5x are from the joysticks to analogues into the PIC, the 6th is from the Altimeter and is digital, 7 is Spare and is a WORD, and Number 8 is fromt the Digital encoder into the QEI PINS of the PIC.
C
