- Joined Jan 23, 2018
- 28,320
Over my career I have seen very few relay failures, except in the very cheapest of consumer junk, and cases of extreme mechanical abuse. ( A fork lift ran into a control panel.) When those few failures did occur they were usually caused by abnormal conditions, or gross misapplication of a relay. They do eventually wear out and become unreliable, but that takes many thousands of operations. I have never seen a relay fail because of "carbon build up" on the contacts, although open-frame relays are subject to dust accumulations. Power relays used to switch very low power analog signals will become unreliable, that is a clear case of choosing the wrong kind of relay.IF a relay coil fails it falls to its de-energized state. Meaning the NC will be closed. However, a relay can fail in other ways: The contacts can build up carbon and fail to switch, meaning they switch but do nothing. The other way a relay can fail is the contacts can become welded. They can weld in the NC position OR in the NO position. With welded contacts you lose control of the circuitry. That - at sea - can be a problem.
To a non-nautical guy like me, I can't imagine all the possible dangers. I may even imagine an un-real danger. The point is that nobody here wants you to get hurt. Or for your system to harm others. That's why safety is both the first and last concerns - especially in an area where you can't just pull over and wait for help to arrive.
But a correctly sized properly chosen relay for power switching will usually outlast the system that it is installed into.
Finally, consider the RV power converter box that outlasts the travel trailer that it is installed into. So there would be another option.
