Quick question. Need a more detailed explanation of how a suppression diode works in a DC circuit. Example would be horn circuit.
Pin 86 = B+ on control side
Pin 85 = Ground on control side
Pin 30 = B+ on load side
Pin 87 - Load
Questions:
a)Magnetic field collapses. Where does current go after switch is opened. Explain using conventional theory.
b)Why does it not just go to ground and if it did, where would it go from there.
c)What would happen if it heads back to power source?
d)What would happen if there was no diode?
e)Why can't the diode be placed in front of the coil instead of across it?
f)Why do some companies use a resistor?
I had this discussion with one of my students today. I want to see if I answered him correctly or whether you gents have a better viewpoint. They were all good questions. Thank you in advance
Pin 87 - Load
Questions:
