MisterBill2
- Joined Jan 23, 2018
- 28,290
It would be a repeat cycle timer that would momentarily open the relay coil circuit, either by switching off a semiconductor device or by opening a contact in series with the relay coil. If it were an actual semi device then the power source connection would require careful evaluation to avoid a crossed circuit condition.How? I can't see it. Not unless there's another relay controlling the main charging/load-switching relay.
