- Joined Jan 23, 2018
- 28,279
It could work to have the diode in the relay coil circuit so as to not drop the charging voltage. And the MUCH SIMPLER scheme will be to use a different switch!!
The best choice will be a DPDT center off switch! In one side it will connect the charger to the battery directly. In the center, everything is off. In the third position it will connect the loads to the battery.
Of course, if the TS does not want to use a switch, but rather control everything by switching the charger on and off with a mains side power switch,, it does get more complicated. The simple fix then is to use a second, mains powered, cheap, small power supply, to operate the relay only. That supply will not even need to be regulated.
