Relay Coordination problem #2. please help!
WBahn
Joined Mar 31, 2012
33,321
You need to not use the same title for two different threads. Doing so causes unneeded confusion on the part of people that might otherwise be interested in helping you.
You have been told repeatedly that you must show your best attempt in the Homework Help forum. We are not interested in doing your work for you, even though that would be the far easier route for most of us, since that will not help you learn anything.
If you can't even get started and can't show anything, then it is probably time to drop the course and either retake it or perhaps its prerequisite courses. Continuing on will likely just dig yourself into a deeper hole that will just get increasingly difficult to ever get out of.
If all you want is someone to do your homework for you, then this isn't the place. There are plenty of sites where you can pay someone to cheat for you. This isn't one of them.
