i get output voltage sine wave with only 0.4 volt. can anyone explain me why this happens? and provide me a solution if it is possible
scope which is connected after the transformerHi,
You had shown 3 scopes .Which scope is getting 0.4V .Please tell us.
pulses for rectifier stageHello,
What you are showing is just a block diagram.
There is no information at all about the control signals.
Bertus
actually output of the rectifier stage is perfect without connecting the inverter stage but when i connect inverter at the output of the rectifier graph becomes distorted. i will send you the graph if you wantHello,
Those pictures do not say wich thyristors are switched when.
The thyristor signals should be synced with the input AC.
A time graph would sy much more.
Also on the output the signals should also alternate.
And again a timegraph will say much more.
Bertus
you are saying transformer at secondary side. If that you meant, the switching circuit is not functioning(oscillating).
i m using igbt, even if i m using mosfet i get the same outputHi,
See your Base signal if available and goes out to collector. You are using bipolar transistor not mosfet.
