Reduce Frequency of Waveform
BobTPH
Joined Jun 5, 2013
11,664
It cannot be done with analog circuits.
Since you won’t tell me what resolutions you need, I will make some assumptions, making it fairly low.
1ms time resolution. Pulses are digital, all the same voltage.
For 1 second of input, you need 500 bits of storage. Not practical with analog.
WBahn
Joined Mar 31, 2012
33,282
Dear all, I have restructured my question to make it more concise :) .
In the future, don't make significant modifications to a previous post that already has responses to it -- you remove the context of those responses so that nothing makes sense for future readers of the thread. Instead, just make a new post with the clarifications.
WBahn
Joined Mar 31, 2012
33,282
Dear all, may I ask if there is a circuit that produces the following input and output which basically reduces its frequency by 2 times which also basically stretch out the input waveform to produce the following output?
Thank you for reading :)
What you are asking for is not realizable, even with a microcontroller, because you would need to have a definitive start time as a reference.
Alec_t
Joined Sep 17, 2013
15,158
As a hybrid analogue/digital solution for pulses in the audio frequency range you could record a pulse train as an audio signal using Audacity, then play back in Audacity at half speed.
BillB3857
Joined Feb 28, 2009
2,573
If I were to use an analogy, you have a bucket being filled at 2gal/min and want to empty it at 1gal/min. How are you going to keep the bucket from overflowing?
