Reduce cutrrent of SMPS
Bordodynov
Joined May 20, 2015
3,433
Do you want to limit the maximum load current ?. Do you want to remake the circuit? Or do not you want to redo the scheme and everything will be done magically? Theoretically, this is possible (reworking the scheme).
dendad
Joined Feb 20, 2016
4,642
Your power supply will only supply the current the load needs. UP TO a max of 8Amps. If you load only draws 2 Amps, that is all it will supply. You don't keep the voltage the same and reduce the current to the load by changing the power supply. You have to change the load.
There is nothing at all wrong with running a 2A load on an 8A supply, as long as the volts are ok.
In fact it is better to have a larger current capacity supply than to run the supply at its max current.
mcgyvr
Joined Oct 15, 2009
5,394
Avijit,
The basic concept that you do not seem to know is that typically the load/device attached to the power supply will only "draw (or pull)" the current it needs from the power supply..
The power supply does not "push" 18 Amps into your load..
18 Amps is just the maximum current that can be safely "drawn/pulled" from the power supply
Just like a car can go 150+ km/hour but your foot controls how fast it really goes..
It has the potential for 18 Amps but the load will draw only what it needs..
You do not need to do anything.
Your device says "hey power supply.. I'm going to take 2 Amps" and the power supply says "ok" the power supply does not say "screw you device.. you asked for 2 Amps and I don't care what you want so here is 18 Amps"...
Now there are certain specific instances where that basic information is not true.. (a discrete LED might be one of those specific situations.. an LED needs to be fed the proper amount of current)
So to continue this conversation please tell us exactly what you want to hook up to this power supply so we can tell you if you need to do anything special or if you just hook up your device to the power supply directly..
Is this an LED? If so please provide us with the part number or link to the datasheet..
gerty
Joined Aug 30, 2007
1,305
What is it you are trying to do? What are you trying to limit the current to? It is easier for us to help you when we know what your goal is.
G Analog & Mixed-Signal Design 34
