Rectifier Filter alternate Dc or Vr P-P calculation.
Petrucciowns
Joined Jun 14, 2009
62
I have a predicament. I'm trying figure out the P-P ripple voltage of a Half-Wave rectifier filter, but the only equation I have is: I / (f * C) yet to find the current I need the DC voltage which I don't have yet.The same goes for the DC voltage. I have the equation: VDC = VOUT P – (VR P-P /2) yet I do not have the ripple voltage yet. So my question is, are there any alternate equations that will allow me to find the ripple voltage without the DC voltage, or the DC voltage without the ripple voltage.
Thanks.
Jony130
Joined Feb 17, 2009
5,600
Well, if we have the transformer that give as 12Vrms (secondary voltage).
12Vrms=16.9Vp
The capacitor (with no load connection) will be charge to
Vc=16.9V-Vd≈16.2Vdc
And if we connect C=220uF and RL=1K
Vpp_ripple=1/(F*R*C)*Vc=1/(50Hz*1K*220uF)*16.2V=0.09*16.2V=1.5Vpp
Vout_dc≈(16.2+14.7V)/2≈15.4V
These calculations assume that transformer voltage are constant. They don't change with the load.
As we know this is not true for real circuits.
Petrucciowns
Joined Jun 14, 2009
62
Hm the ripple current equation is not seeming to give me the right answer. Could you possibly do an example with these values.
Vout Peak- 169.3 volts 12 micro farad 15kohms 60hz and a forward biased silicon diode.
The answer for Vr p-p should be an exact 15 volts p-p
Also with your DC equation Vout_dc≈(16.2+14.7V)/2≈15.4V
Where does the value of 14.7 volts come from?
Thanks.
Petrucciowns
Joined Jun 14, 2009
62
Thank you, is there a similar equation for center tapped full-wave rectifier filters such as:
60 hz 24.3 v p output 1000 micro farad 100 ohms
Because I noticed that equation is only for half wave. The answer to the above should be around: 1.94 v p-p
Thanks.
Jony130
Joined Feb 17, 2009
5,600
Well the equation is exactly the same
\(Vpp_{ripple}=(\frac{1 }{F*R*C})*Vin_p\)
But the frequency is 120Hz for bridge and center-tapped full-wave rectifier.
So Vpp_ripple≈1.96V
And in my previous calculation I forgot about diode and her voltage drop.
Petrucciowns
Joined Jun 14, 2009
62
With the the values in my last post I get a different answer. What am I doing wrong
1/ (120 x 100 x 1000 micro) x 24.3 = 2.03 Volts
When it should be 1.96 volts like you have above.
