Recommend protection schemes for a very high voltage converter DC-DC
SiCEngineer
Joined May 22, 2019
444
Hi all,
I have just about completed a design for a -6kV and -3kV output converter. I have current limiting at the front end, but was wondering what are the other schemes I should implement to ensure that I can work safely on this converter with such a high voltage.
I am thinking of having a comparator driving about 3 LED's which work as indicators for different voltage levels for the converter. But I was also thinking maybe I could do something else with this if an overvoltage condition is detected. Is a standard overvoltage protection circuit recommended?
Can anyone recommend a circuit which works well for high voltage and will minimize risk to myself when working with this converter? Power is 600W and currents shouldnt exceed 200mA in secondary. I have been looking at current foldback limiting which is on the secondary side - maybe this would work alongside the main primary side current limit?
Delta Prime
Joined Nov 15, 2019
1,311
Hello, :) I was thinking maybe a self recovery overload short circuit protection function,anti-static, anti-surge,voltage is unchanged when it at no load,safety isolation in ground loop elimination.You're probably familiar with these specs are common.
SiCEngineer
Joined May 22, 2019
444
Thanks for your reply! Have you got a reference for where this came from which may include some typical circuits good for overload short circuit protection?
I may add that my load is modelled as purely resistive because the actual equipment is very expensive. Usually they use a spark gap for this equipment (travelling wave tube) But I won't need that since I am not using it in the converter. This is for research purposes. :)
Delta Prime
Joined Nov 15, 2019
1,311
Hello! again :)
Boy, I believe I got that reference chart from IEEE website.
Would you mind if I could see what you have so far?
DC voltage converters operate in one or another of four basic ways and use a DC-powered oscillator to drive either a simple diode-capacitor ‘voltage multiplier’ network, or a step-up transformer and rectifier network, or a ‘flying capacitor’ voltage converter, or a ‘diode-steered charge pump,’ which produces the desired final DC output voltage or voltages.
Which flavor topology are you employing.:)
please don't say your
Circuit contains a 555 timer.
:rolleyes:
