Recommend me Pic microcontroller for this project
gaber2611
Joined Mar 14, 2013
331
Hello
Please recommend Pic microcontroller for this project.
5 buttons and 6 led strips
Also that's only the available space
13*20mm
Messenger_creation_9720802F-9A34-4441-BAB4-D0F9BD1FAC83.jpegim thinking of Pic 16f877a, how you think?
gaber2611
Joined Mar 14, 2013
331
Okay, thanks im thinking of 16f886, the smd package, it's within dimensions I need, suitable for this pcb size
Do you have an idea which command suitable for programming the Pic to do these tasks mentioned above?
I want a pin in the Pic to be on, when press a button
And if I press the same button again, this pin goes off, and another pin goes on
If press again, the last pin is off,
Also need pwm control pins, to control the brightness led
How this can be written in mikroC compiler?
I'm trying to learn about it these days, biyt if you can help would be much appreciated
Regards
MaxHeadRoom
Joined Jul 18, 2013
30,808
I modified a LED lamp recently for a member, it had 3 sets of LED strings that were controlled independently, i.e. fade in, fade out, , I ended up using a pic version where the PWM output could be switched to 3 PWM output pins on the fly in order to sequentially control the three strings..
gaber2611
Joined Mar 14, 2013
331
Do I need 6 pwm output for control the brightness?
MaxHeadRoom
Joined Jul 18, 2013
30,808
For the application I had the three banks of LED's were each controlled by a separate output, each bank in turn..
The PWM width was varied from zero to maximum by using a timer to change the PWM width, every 'Tick' of the timer would increase or decrease the PWM width accordingly.
gaber2611
Joined Mar 14, 2013
331
Do you have a PicKit to use to program it?
Yes, have and
For my project?, how you think the pwm should be configured? With the Pic and leds?
be80be
Joined Jul 5, 2008
2,395
Do I need 6 pwm output for control the brightness? Nope just 6 ouputs and 1 pwm if you want dim all 6 the same if not
Then you need 6 of them
be80be
Joined Jul 5, 2008
2,395
Can you write what you want to happen like flow of how you want it to happen post 3# is not that clear
You need to to list all 5 buttons
And what happens to the 6 led strips
mikroC probably not that hard to write the code.
gaber2611
Joined Mar 14, 2013
331
I need when I press button it light one led led strip, and when I press again it off that led strip and light other one, and when I press again it off the last led strip and that's all
For every led strip the same, as every two led strip controller by one button
BTW, two buttons for increment and decrement the lighting of led
" pwm", one button increase brightness by a percent when pressed or increase gradually the brightness when pressed all time and same for decrement
That's all
Regards
