asked Chatgpt to recommend some upgrades/modifications for my Akai MPC3000
fknchino
Joined Apr 18, 2017
So I made this post in 2017: output boost mod and thought I'd come full circle (almost) a decade later with the following proposition.
Now many of us know not to fully trust in AI, so I hope i've come to the right place and ask some clever individuals if this would be a 'good' or 'bad' idea. Basically, I want to refresh the MPC3000’s audio front end and power for the converters – not a full recap, but targeted ‘audiophile-ish’ parts.
(I've also uploaded the schematics below)
P.S. I know this is not an Audio/sampler forum, but I feel you guys can chime in with an unbiased opinion.
Any input is greatly appreciated. Thanks in advance.
So this was the TLDR recommendation:
  • Swap all record + output op-amps for TI LME49720NA.
  • Replace all audio-path electrolytics on AD/DA + BDACS boards with Elna Silmic II / Cerafine (values mapped as above).
  • Refresh the analog PSU caps with Panasonic FC 470µF/25V and 2200µF/35V.
  • Renew the 5 V / ±12 V regulators with modern TI parts.
  • Upgrade the 8-out 100 Ω series resistors to Vishay CMF55 metal-film.”
1. What to replace (concrete targets)
To get audible improvement without going insane / risky:
A. Audio op-amps (record + 8 outs) – highest impact
Goal: lower noise, cleaner transients, better stereo image.
  • Replace all dual audio op-ampsin:
    • Record input / main analog input stage
    • Individual outs / stereo out driver stages (BDACS / AD/DA boards)
  • Choose: Texas Instruments LME49720NA/NOPB – high-end audio dual op-amp, DIP-8. (DigiKey)
Qty assumption: ~6 dual op-amps total across record + main outputs on a typical MPC3K.
B. Audio-path electrolytics (record + outs)
Goal: lower ESR, more stable, nicer “hi-fi” voicing.
Target all electrolytic caps that sit directly in the audio path or as local decouplers around those op-amps:
  • Input coupling caps
  • Output coupling caps
  • Local rail decoupling right next to op-amps
Premium choices from TubeAudio AU (all in stock at time of lookup):
  • Elna Silmic II 220µF 16V Radial – silky, warm; great for coupling & local decoupling. (tubeaudio.com.au)
  • Elna Cerafine 100µF 25V Radial – tighter, punchier; good for rail decoupling & some coupling spots. (tubeaudio.com.au)
  • Elna Cerafine 220µF 10V Radial – for any 220µF parts sitting on low-voltage analog rails. (tubeaudio.com.au)
Qty assumption for audio section:
Roughly 20–24 audio-relevant electrolytics split across record + 8-outs.
I’ve allocated:
  • 12× Silmic II 220µF/16V
  • 8× Cerafine 100µF/25V
  • 4× Cerafine 220µF/10V
C. PSU analog electrolytics + regulators
Goal: quieter ±12 V and 5 V rails feeding the audio / converters.
  1. Analog rails decoupling / mid-sized bulk
    • Replace 470µF-class caps sitting on ±12 V near the audio boards with:
    • Panasonic FC 470µF 25V Radial 105°C (TubeAudio AU). (tubeaudio.com.au)
  2. Main analog PSU reservoirs
    • Replace the big electrolytics feeding the ±12 V analog rails with:
    • Panasonic FC 2200µF 35V Radial 105°C (TubeAudio AU). (tubeaudio.com.au)
  3. Linear regulators (keep it simple and robust)
    From DigiKey AU (all TO-220 through-hole):
    • +5 V: TI LM78M05CT/NOPB 5 V / 500 mA. (DigiKey)
    • +12 V: TI LM7812CT/NOPB 12 V / 1 A. (DigiKey)
    • –12 V: TI LM7912CT/NOPB –12 V / 1.5 A. (DigiKey)
  4. Your tech must:
    • Verify pinouts vs originals
    • Reuse or improve heatsinking
      But these are very standard swaps.
D. 8-out series/output resistors
Goal: super-stable output impedance and top-shelf parts right at the jacks.
Replace the 100 Ω series resistors on each of the 8 individual outs with:
Not crazy boutique like Z-foil, but genuinely premium and easier to source.
2. Combined parts & price list (approx, no spares)
Assumptions:
  • Quantities are designed to match likely positions (no deliberate “extra”),
    but you must have your tech confirm counts against your specific board revision.
  • Prices in AUD, approximate, per-piece retail at time of lookup (GST-inclusive where given).
You can paste this table straight into Excel (split on |):
Shopping cart (parts + price)
Stage / AreaSupplierPartQtyUnit Price (AUD)Line Total (AUD)Notes
Audio op-amps (record + outs)DigiKey AULME49720NA/NOPB (TI) – dual audio op-amp DIP-8 (DigiKey)613.8783.23Replace all dual audio op-amps on AD/DA + BDACS/audio boards (record + 8-outs). Price from DigiKey AU “with GST”.
8-out series resistorsAny (Arrow / Farnell etc.)Vishay CMF55100R00FKEB – 100 Ω 1% metal film (Arrow Electronics)8≈1.2510.00One per individual out. Price estimated from ~US$0.83 each → ~A$1.25.
Audio caps – coupling / local (bigger)TubeAudio AUElna Silmic II 220µF 16V Radial (tubeaudio.com.au)124.0048.00Use anywhere you have 220µF/≤16V in audio path or local decoupling (record + 8 outs).
Audio caps – rail/decouplingTubeAudio AUElna Cerafine 100µF 25V Radial (tubeaudio.com.au)84.0032.00Swap 100µF/16–25V caps around op-amps & filter stages.
Audio caps – low-V bulkTubeAudio AUElna Cerafine 220µF 10V Radial (tubeaudio.com.au)43.0012.00For 220µF caps on low-voltage analog rails (e.g. near DAC/ADC refs).
PSU analog decouplingTubeAudio AUPanasonic FC 470µF 25V Radial 105°C (tubeaudio.com.au)41.004.00For ±12 V rail decoupling near the audio boards.
PSU main analog reservoirsTubeAudio AUPanasonic FC 2200µF 35V Radial 105°C (tubeaudio.com.au)42.5010.00Replace the big electrolytics feeding ±12 V analog rails.
PSU 5 V regulatorDigiKey AULM78M05CT/NOPB (TI) 5 V / 500 mA reg, TO-220 (DigiKey)12.252.25Replace existing +5 V linear reg feeding digital/ADC sections, if compatible.
PSU +12 V regulatorDigiKey AULM7812CT/NOPB (TI) 12 V / 1 A reg, TO-220 (DigiKey)13.143.14Main +12 V analog rail reg.
PSU −12 V regulatorDigiKey AULM7912CT/NOPB (TI) −12 V / 1.5 A reg, TO-220 (DigiKey)12.572.57Main −12 V analog rail reg.
Approximate grand total (parts only)
If you add all those line totals:
  • Total ≈ A$207.20 (plus shipping from DigiKey + TubeAudio + whoever you use for the Vishay resistors).
If you've read this far. Thank you again I really appreciate it.
Futurist
Joined Apr 8, 2025
952
You are effectively asking people to predict the performance of the updated system and compare it with its current state.
I doubt anyone can do that, you might was well pick up an identical unit from ebay, do your upgrades and then compare their performance.
