Read FUSE bit and modify without effect any damage to program space
micropad
Joined Dec 24, 2011
109
Dear All
Have a nice day
I need read the fuse bits of PIC18F2550 and modify it and to be re programmed without any damaged to the program space
Please advice about programmer and software
Thanks in advanced
micropad
Joined Dec 24, 2011
109
Source code can not be given to end user
If I want to do improvements and new release
I should need to know, it should possible or impossible ?
jpanhalt
Joined Jan 18, 2008
11,087
Are you the end user or the manufacturer? Setting the appropriate fuse protects the source code from the end user. If you are the manufacturer/IP owner, then you should have that code. Do you or your company own that code?
micropad
Joined Dec 24, 2011
109
Our Company is the legal owner of the code and I too have them
Currently we provide hex code to the our technical staff to upload the code to the end user location . but company is requesting to find the solution upgrade firmware some other way without giving to technician
Papabravo
Joined Feb 24, 2006
22,111
  1. Disassemble the hex code
  2. Create new assembly language source files from the disassembly listing
  3. Modify new source files to suit your requirements
  4. Assemble the new source files
  5. Program new or update existing parts from new hex files
Easy peasy, for an accomplished firmware jockey like myself. Having done it several times helps.
micropad
Joined Dec 24, 2011
109
I have source code
Papabravo
Joined Feb 24, 2006
22,111
I have source code
Then I fail to understand your problem. You modify your source code and reflash the part. In order to do that the code protect bits must be reset by a bulk erase. That is their whole purpose in life, to prevent those without the source code from doing what you describe.
micropad
Joined Dec 24, 2011
109
Is there any hex upload procedure by end user without reading code in side the MCU
be80be
Joined Jul 5, 2008
2,395
Bootloader then in user can load firmware themselves. Bootloader can be made to read firmware to load so as
user can't. crypto-Bootloader
