Hi guys, this one is really scratching my head and I'm pretty sure it's simpler than I'm cooking up in my head!
I'm designing a trigger circuit for a 'laser tag' system. S1 represents the laser blaster's trigger, R1 is the Current limiting resistor for the output diode (Actually a Transistor output driver but for simplicity just a resistor), and R3 is a preset potentiometer to adjust the output pulse duration.
It needs to output a pulse from ~50 - 120ms, and not be able to re-trigger until the trigger switch has been released.
I have designed the monostable oscillator circuit without issue, the output is exactly what I need it to be:
However, if the 'trigger' is held down (ie: low), the output remains high. This is registered by my windows based system as a constant input and your 'blaster' then acts as a mouse:
How do I go about preventing my circuit from re-triggering until the trigger switch has been released (ie the input pin has gone HIGH), so that the user can shoot as fast as they can pull the trigger?
Thanks in advance!
Thanks in advance!
