Rail to Rail op amp recommendation
Danko
Joined Nov 22, 2017
2,199
OPA2340UA
$ 0.95/lot (Lot 10 pcs)
• Rail-to-Rail Input
• Rail-to-Rail Output (Within 1 mV)
• MicroSize Packages
• Wide Bandwidth: 5.5 MHz
• High Slew Rate: 6 V/µs
• Low THD + Noise: 0.0007% (f = 1 kHz)
• Low Quiescent Current: 750 µA/Channel
• Single, Dual, and Quad Versions
CaptainBrock
Joined Oct 31, 2022
7
So, "rail-to-rail" may refer to either input or output range. I'm surprised how people most often are not clear on that.
I recently acquired (but have not yet tested) T.I. TLV9062IDR and Microchip MCP6002T-E/SN (mentioned above.) They both look good on the datasheet. I'm operating at 5.0 volts single-sided supply.
32,999
The term "rail to rail" almost always refers to the output voltage swing.
When talking about the input, the usual terminology is something like, "common-mode input includes the rails". Even this is misleading if interpreted strictly. If the positive rail were 10 V and one input was 7 V and the other input was 12 V, then the common-mode input is 9.5 V, but this would almost certainly not function as intended. But saying that the common-mode input includes the rails gets the point across, especially for opamps since if there is much difference at all between the two inputs the device is going to saturate anyway.
ci139
Joined Jul 11, 2016
2,008
⚠ an LTspice test log from years ago
Pass TEST
► TLV314 -- struggles near rails but passes (1.8÷5.5V) ◄
?? ~ TLV2371 -- inp max 2.58V ~ ??
► TLV9102 -- struggles near the low rail but passes (2.7÷16V) ◄
?? ~ TL3472 -- inp min max 1.0 to 3.4 V ~ ??
?? ~ OPA2990 -- inp max 2.49V ~ ??
OP284 struggles near rails but passes better the TLV314 (3÷36V) ◄ ← this has performed superior to the rest at many cases ? at simulations
?? ~ LMV824 -- inp MAX ? 3.1 to 3.8 V (exact value indeterminable) ~ ??
► LM7321 -- struggles near the rails but passes smoother than OP284 (2.5÷32V) ◄
► LM6142 -- same as LM7321 but faster (1.8÷24V) ◄
► AD8628 -- struggles near rails but passes somewhat worse the rest R2R passers (2.7÷5V) ◄
