Raidmax and pc LEDs
BruceY19
Joined Apr 22, 2020
5
Hello, I have 3 Raidmax led fans for my pc case. I don't have controller and mobo doesn't have right connectors. I did purchase a COOLMOON RGB CONTROLLER, and also a JST 2.0 crimp tool and connectors. I swapped connectors so fan could plug into COOLMOON WIRE FOR WIRE. These fans have LEDs around the circumference. When powered up, the Leds lit up Brite white. could not control color. Fan blades not spinning. I had read somewhere Raidmax fans only work with Raidmax controllers. Anyone hear this?
28,224
It seems that the TS needs to know the correct connections for their fans to a different controller.
The bad news I bring is that there is no universal common connection scheme for almost all stuff. The big exception is for 120 volt mains power plugs and modular telephone connections. And USB connectors are fairly standard, except for all the different sizes.
