Questions and Problems about DS1307 RTC including EEPROM and not working the timer
Saeedk9574
Joined Jan 1, 2024
35
Hi Everyone,
It has been a few days that I have been struggling with DS1307 RTC and I have some questions and problems. I should mention I had tested a library for ds1307 on its prepared module, then I decided to make the circuit separately with its components. These are the ds1307 module pic and its circuit diagram. In addition I attached ds1307 and its module datasheet here. However, there was not appropriate datasheet for its module.
View attachment 187789View attachment 187790
1. Based on the datasheet ds1307 has 56B nvSRAM, so my first question is what is the usage of eeprom in this module? is it necessary to use eeprom on my board or not?
2. Second, I have a very big problem. After creating this circuit on PCB, it works correctly when the board is fixed on its place. But sometimes by a simple movement of the board the timer gets stuck and sometimes it works well. My first guess was the crystal oscillator stops working by moving the board. But then I decided to touch crystal by my hand to test it and it was OK. I do not know where is the problem.
3. I should mention the only difference between the module and my circuit is the type of eeprom. Module has a 32K eeprom (24c32), but I used a 1k eeprom (24AA01). Can this difference affect the performance. I still do not know the usage of eeprom here.
ericgibbs
Joined Jan 29, 2010
21,652
Hi Saeed,
You do not need to use the EEPROM in the DS1307 in order to operate the DS1307.
Please post a clear photo of the PCB, front & back, so that we can check the layout.
E
Saeedk9574
Joined Jan 1, 2024
35
Hi Saeed,
E
I appreciate you for answering,
About eeprom do you have any idea how can I use it in this RTC.
And about the board. It is not in access now I can send it tomorrow, But I can send its design in Altium. I think there is connection problem. My second guess is about fuse. I suppose it is not fixed in its box, and by moving it gets disconnected for a moment. Is there any other component that can disrupt connection.
