- Joined Jan 23, 2018
- 28,600
You are correct, and that is the reason that I suggested researching the designs available. And still, connecting to a yagi antenna that is optimized for gain or directionality may require a matching system. Even the best antenna requires correct matching to deliver the best performance.MrBill2 - Note that impedance of Yagi is dependant too (and adjustable) by changing the distance between elements, and as the last method, by inclining the director in small angle (maybe 5...20 deg) ends toward mirror. Such manner is not difficult to get 50 Ohm out of typical 73 Ohm construction as I described here time ago this summer.
