Hello! Although I'm a member of this forum for some time and I have been helped a lot, it's the first time I need to post something...So, I need your advice for a circuit I'm working on. Any help will be much appreciated!
What I want to do is to drive two ignition coils in anti-parallel formation. So I found the basic PWM principles and customized it to my needs. The circuit has two different sources (220VAC to 12VAC transformer rectified to 12VDC), a 555 timer with a 393 comparator in order to keep the frequency and the duty independent to each other. The two sources drive two different IRFP460 MOSFETS.
Now, what I need to know is:
1)Do I have to reverse the polarity of the second mosfet (the one at the bottom) as well, or I can just connect the coil with reversed polarity?
2)The switching current (amperes) of the MOSFET or the transformer's max. current has to be larger? In other words, a MOSFET with max 20A switching current and 10A transformer or 15A transformer with 10A MOSFET combination would be better?
The schematic is this, thank you once again for any help!
