Pwm to MOSFET
sghioto
Joined Dec 31, 2017
8,751
Yes it's required to pull the gate to ground potential otherwise the FET will most likely always be on if the PWM generator is not connected.
The PWM generator has a 50 ohm output impedance so the 10K resistor will not have any effect on its output. Install the 10K resistor regardless if the generator is always connected.
sghioto
Joined Dec 31, 2017
8,751
What if I was to use an IRF9Z44NPBF, would the configuration be the same as IRLZ?
The leads of the transistors are marked the same but wouldn't recommend using.
The output from the PWM generator was stated at 10Vpp. That's only 5 volt peak and the reason why I suggest using the logic level mosfet.
MrAl
Joined Jun 17, 2014
13,797
We are studying ISO transients and are building a load box. This load box has an N channel MOSFET and 47nF capacitor. The input will be 13.5 volts and up to 1.4 amps. The output will be wired to a connector to a harness that will be connected to a circuit board with 40 LEDs and the duty cycle is 65pct. How would I go about wiring the pwm and Vbat? I attached a small schematic. I am thinking about using VN2210 for the FET but maybe I should use something different?
I see you had a number of replies already, so I'll just add a little.
I see you have a capacitor on the output of the mosfet. That's usually not a good idea because it will cause the mosfet to have to conduct large spike currents. I'm not sure if that cap is really in the circuit though you can verify that.
There other thing is the generator. Does the output really have a 50 Ohm output impedance? I ask because it is not good to drive a mosfet gate with a device that has too high of an output impedance or that could cause slow rise and fall times which would heat up the mosfet more than needed.
They make dedicated mosfet driver chips for that, but you may not need that.
scam313
Joined Jul 19, 2022
44
Hello, it does say on the datasheet for the keysight generator amplitude range 10vpp into 50ohms. Thanks
