Push-Button switch with delay to Turn On/Off Raspberry PI
Kevin Pilgrim
Joined Sep 14, 2018
Dear Forum,
For a mobile project I need a circut to turn on/off a raspberry pi with delay. Idealy with a 2-3 second delay to prevent that a user accidentally powers on or off. Since the PI also has a HDMI Display attached the maxmimum current is 1A. I tried this here http://www.mosaic-industries.com/em...n-switch-turn-on/latching-toggle-power-switch but I did not get it to work.
I would like to implement it with SMD ic/components.
Thanks for any helP!
38,676
Below is a toggle delay circuit that should do what you want.
U1 and U2 can be any inverting gates, such as a CD4001 NOR gate, or a CD4049 buffer.
The LTspice simulation shows a delay of about a 2.6 seconds for both turn on and turn off.
M1 can be just about any logic-level (max Vgs threshold of ≤2V) P-MOSFET with an on-resistance of ≤100mΩ.
KMoffett
Joined Dec 19, 2007
2,918
It appears that all the circuits that use logic gates must remain powered even when the switched load is off. Or am I wrong?\
Ken
AnalogKid
Joined Aug 1, 2013
12,238
1. Do you want the circuit to wait 2-3 seconds after a brief momentary button push and then switch the power?
-or-
2. Do you want the user to have to hold down the button for 2-3 seconds before the circuit switches the power?
ak
38,676
Does this look about right ;-)?
That will work but you only need one chip, not two.
There are are 4 gates in each package, and you can use two of them for the circuit.
Due to C2 and C3, the circuit I posted should come up in the power-off state when the power is applied.
And it takes only leakage current when energized in the static state.
-or-
Since he stated
I would think it's number 2.
KMoffett
Joined Dec 19, 2007
2,918
But you don't show any power for U1/U2. When Vdd is supplied, but the output to the load is OFF, doesn't U1/U2 still have to be connected to Vdd, drawing a small current?
Ken
38,676
Yes.
But the CD4011 data sheet states that the quiescent current is less than a microamp, which will be insignificant for all but the smallest battery source.
