How to short 3 terminals with push button switch?
Nick Papachristou
Joined Feb 24, 2025
6
How to sort 3 terminals with push button switch?
Try to replace damaged membrane keypad with push swithes.... is it possible?
There are 3 terminal to short in order to work
35,320
Usually, control signals need to be pulled high or low. You can do this with transistors.
If this is not the case, use analog switches to connect the terminals.
BobTPH
Joined Jun 5, 2013
11,678
Why do you need three switches? It seems quite simple to me short 3 terminals with two switches. Maybe we have a different understanding of what he is asking for.
Terminals A B & C
Switch 1 between A and B
Switch 2 between B and C.
35,320
Terminals A B & C
You're right. I didn't think of that. All you need is a DPST or DPDT pushbutton.
BobTPH
Joined Jun 5, 2013
11,678
However, I am doubtful that a membrane keypad is actually doing that. Don’t see why it would use more than two terminals.
TS: Are you sure two of the terminals on your keypad keys are not already shorted together?
35,320
Yes. The information provided by TS is lacking, again typical of the X-Y problem. But I did not bother to pursue it.
Nick Papachristou
Joined Feb 24, 2025
6
here is the chart:
1-2-6
1-2-7
1-2-8
1-2-9
1-3-6
1-3-7
1-3-8
1-3-9
1-4-6
1-4-7
1-4-8
1-4-9
1-5-6
1-5-7
1-5-8
1-5-9
its seems all connected to common #1
how to to that with 1 push button swhich?
Nick Papachristou
Joined Feb 24, 2025
6
yes #1 and #10 are sort together. How to sort 1,2,5? or 1,3,5, etc
