Pulse on closed circuit and on open again. (converting toggle switch to momentary)
38,813
I think this should do the job :
Unfortunately that circuit will have glitches at the output due to the mechanical switch bounce.
Below is a circuit using CD4093 Schmitt trigger NAND gates to generate the XOR function with added debounce function.
Note that the output doesn't respond to the simulated input bounce (yellow trace) at the start.
