pulse circuits with MOSFET
yerff
Joined Sep 9, 2013
3
Hello all,
I'm new to circuit and in fact I'm more of a mechanical student. I have a problem
to an experiment which requires me to continuously apply square pulse of between 10-35V, where the rise time of the pulse should be faster than 50us, dwell time of 250us and regardless of fall time.
I was told I can do it with a mosfet, so I bought some fujielectronic MOSFET, 2SK3362-01 and tried to give it a shot.
I attach the simple connection schematic I tried, The drain is connected to a Agilent powersupply, 25V. When I turn on the function generator, it seems like the voltage rise is slower than I what I need, and if I increase the frequency, the voltage can't even rise to 25V, could it be due to the power supply? Or is there something wrong with my circuit??:confused: Please help.
thanks,
Yerff
shortbus
Joined Sep 30, 2009
10,049
@Yerff and Experimentomen, not the pull down resistor, but the one between source and ground. With a resistor in that position it makes your mosfet essentially a high side switch. It starts to turn on fast then slows down as the source voltage rises, when you add a component between source and ground. What you are wanting to do is called a 'low side switch', the source should be connected directly to ground for that.
