Pulse amplifier using a opamp and MOSFET's
ZweedNaat
Joined Feb 15, 2017
25
Below I have pasted the screendump of a circuit which I've simulated in LTSpice. It looks as though it will do what you want. I am assuming your input signal is bipolar since you want a bipolar output. The first stage is a differential amplifier and the second a non-inverting booster. As you can see from the screendump the output voltage into the capacitor ranges fron +9.5 to -11.3. There is a phase difference between input & output but that is unavoidable. You didn't specify zero plase difference in your original spec. Phase compensation would add more complexity to the circuit. I have omitted bypass capacitors in the simulation - you will have to put those into the physical circuit to remove power line noise, as the amplifier gain is very high. As you can see, the CA3140 opamp is sufficiently fast for this application and is much cheaper than using the much faster slew rate op-amps which you mentioned in post #9. I have used the largest load capacitor which you specified (10n) to confirm that the output voltage meets your spec.
I also tried using comparators because they are much faster than op amps as other posters have mentioned. But their open collectors make getting a bipolar output difficult.
This is very, very helpful. The only problem is that I don't have a bipolar input, but I'm sure I can fix that tweaking a little bit on the first opamp. But I'm pretty sure this will work. I will try to build this and test this on a breadboard today.
Thanks a bunch! Really helpfull.
Bordodynov
Joined May 20, 2015
3,435
This also looks really, really helpful. Question though, transistor Q5 and Q6. What are those for? I have a theory, but I'm not sure that theory is right. Can you explain?
Since I will be working on this little project today, I will build and test this as well.
Thanks a lot. Really helpful!
These transistors are switched on for a short time and they significantly speed up the processes (Work in class B).
Sitara
Joined May 2, 2014
57
To convert the unipolar input into bipolar, just pass it through a low impedance capacitor. 10uF should do it.
Sitara
Joined May 2, 2014
57
Gilding the lily...
Have a look at the screendump below. The circuit uses cheap-as-chips parts and look at its performance.
ZweedNaat
Joined Feb 15, 2017
25
I've been struggling with this for a while but finally got something to work. I thank you all for replying and for your help. If somebody want's the scematica and such please feel free to contact me.
I didn't really get to the point where I wanted the amplifier to be but it's close enough...
As I said before, thanks all and hopefully I'll speak to you guys im the future!
