protecting a p channel mosfet gate with a zener.
mike _Jacobs
Joined Jun 9, 2021
223
Have done this in the past lots of times with N channel.
Just want to make sure im thinking about this correctly for a p channel
Is it done the same way?
The cathode of the zener on the gate and the annode on the source?
Its a high side P channel switch.
Which makes me think i want the cathode of the zener on the gate and the anode on the drain?
can someone confirm
dl324
Joined Mar 30, 2015
18,491
Since you can apply either polarity voltage to the gate-source, you'd need back-to-back zener diodes to offer robust protection.
This is how ON Semiconductor did it for NTA4151P:
38,913
Since the P-MOSFET is reverse polarity from an N-MOSFET with a negative Vgs to turn it on, you put the Zener anode on the gate and cathode on the source (t's the gate-source voltage that's of concern).
You don't need back-to-back Zeners, since a plus gate-source voltage will just cause forward conduction in the Zener, as it now looks like a forward-biased diode.
