Project to produce a 10 hour time delay using 8051 microcontroller
Cyfer_135
Joined Nov 14, 2024
14
My prof gave me this project. I can produce the delay but how can i verify that because i don't have that 10 hour to spend in lab. Can you please help me with this.
LesJones
Joined Jan 8, 2017
4,544
Tell us how you plan to get from your time reference (I asume 1 instruction time.) to your 10 hour time. Just a block diagram of the steps. (You don't need to post the assembler source code at this point.)
Les.
meth
Joined May 21, 2016
322
Do you even read what he is asking? :D He says he knows how to make the delay he just doesnt know how to bend time 10 hours forward to confirm its functionality :D
Unfortunately time manipulations arent yet unlocked :) if it is a school project probably the concept you come up with is important, you and the professor would not have to actually sit and wait 10 hours.
Demonstrate how the delay works for 3 minutes, and then show what needs to be changed to work for 10 hours. I really would not know how to speed up time.... except maybe to use crystal with higher frequency on the CPU.
Cyfer_135
Joined Nov 14, 2024
14
Currently, I have idea that i would run my timer until overflow and increase a counter on overflow and then try to extrapolate it to prove to the prof mathematically
Cyfer_135
Joined Nov 14, 2024
14
somewhat like this :- use a timer to make my N(maybe 1sec) delay, then figure out how to count how many N delays have elapsed so that I can count M N delays.
BobTPH
Joined Jun 5, 2013
11,664
can use rtc but the problem is how to prove him that 10 hour delay is being produced. Evaluation might be completed in 1.5 hrs so how can i fast forward the time
You can’t fast forward time, but you can speed it up. Write the delay for a very slow clock rate, then run the clock 10 times faster for the demo.
Cyfer_135
Joined Nov 14, 2024
14
C-like:
#include <reg51.h>  // Use the correct header file for 8051
// Segment codes for 0-9 for 7-segment display (common cathode)
const unsigned char segmentCodes[10] = {
    0x3F, // 0
    0x06, // 1
    0x5B, // 2
    0x4F, // 3
    0x66, // 4
    0x6D, // 5
    0x7D, // 6
    0x07, // 7
    0x7F, // 8
    0x6F  // 9
// Timer 1 overflow delay function
void timer1Delay() {
    TH1 = 0x00;     // Set Timer 1 high byte for full count
    TL1 = 0x00;     // Set Timer 1 low byte for full count
    TF1 = 0;        // Clear overflow flag
    TR1 = 1;        // Start Timer 1
    while (TF1 == 0);  // Wait until overflow occurs
    TR1 = 0;        // Stop Timer 1
    TF1 = 0;        // Clear overflow flag again
// Function to display count on a 4-digit 7-segment display
void displayProgress(int count) {
    int digit1, digit2, digit3, digit4;
    int i, delay;
    // Extract each digit from the count
    digit1 = count % 10;            // Units place
    digit2 = (count / 10) % 10;     // Tens place
    digit3 = (count / 100) % 10;    // Hundreds place
    digit4 = (count / 1000) % 10;   // Thousands place
    // Multiplex each digit for a brief period
    for (i = 0; i < 4; i++) {
        switch (i) {
            case 0:
                P2 = segmentCodes[digit1]; // Send units digit pattern to port
                P3 = 0x01;                 // Enable units place (digit 1)
                break;
            case 1:
                P2 = segmentCodes[digit2]; // Send tens digit pattern to port
                P3 = 0x02;                 // Enable tens place (digit 2)
                break;
            case 2:
                P2 = segmentCodes[digit3]; // Send hundreds digit pattern to port
                P3 = 0x04;                 // Enable hundreds place (digit 3)
                break;
            case 3:
                P2 = segmentCodes[digit4]; // Send thousands digit pattern to port
                P3 = 0x08;                 // Enable thousands place (digit 4)
                break;
        // Brief delay to hold the display
        for (delay = 0; delay < 1000; delay++);
        P3 = 0x00;  // Turn off all digits before next iteration
void main() {
    int overflowCount = 0;      // Counts up to 1000 overflows
    int progressCounter = 0;    // Progress counter to display
    TMOD = 0x10;    // Set Timer 1 to Mode 1 (16-bit timer mode)
    while (1) {
        // Call timer delay function
        timer1Delay();
        overflowCount++;
        // Check if overflowCount reached 1000 (approximately 71.58 seconds)
        if (overflowCount >= 1000) {
            overflowCount = 0;           // Reset overflow counter
            progressCounter++;           // Increment progress counter
            displayProgress(progressCounter); // Update 7-segment display
            // If 600 increments have been reached, we’ve simulated 10 hours
            if (progressCounter >= 600) {
                progressCounter = 0;  // Reset or take any required action
                // Optionally add a signal here to indicate completion
this is my code to realize the delay is it correct or it needs corrections
boostbuck
Joined Oct 5, 2017
1,065
You don't need to spend 10 hours in the lab - all you need to do is spend the time representing the error in your timer. For example, if you are confident it will time 10 hours with max error +/- 10 minutes, you can set it going and come back in 9 hours 50 minutes, only need spend a maximum of 20 minutes waiting for it to time out to determine the actual error.
Cyfer_135
Joined Nov 14, 2024
14
i have written the code just above your reply can you look at it and tell is it correct
MrAl
Joined Jun 17, 2014
13,831
A couple questions for you first:
1. How far off can it be and still be considered correct?
2. What kind of IDE are you working with?
I ask about the IDE because some IDE's let you simulate the working of the controller. That allows you to jump around long code lengths and still see the time accumulated on the timer in the IDE. In other words, if you have code that takes 1 minute to run normally you may jump to the instruction just after that 1 minute block of code. The IDE timer would still show 60 seconds even though it jumped in less than 1 millisecond. You can do this with longer code too. Maybe you have a 1 hour code block, once you jump over that the IDE timer would still show 3600 seconds (1 hour) even though it took less than a second to jump around.
They don't call it a jump though, it might just be a breakpoint.
You can set the clock speed to be faster too, then just multiply by the same amount. So if the IDE timer says 60 seconds and you increased the clock speed by 10 times, it would really have progressed by 600 seconds.
Another way is to make a shorter delay and then just call it a lot of times. If you make a delay that lasts for 60 seconds and you call it 60 times, that's 3600 seconds or 1 hour. If you change that delay to just 1 second, it would execute in 60 seconds, which would be a scaled version of your actual needed time length.
When you do this though you have to take into account the time it takes to call and return from the delay routine, unless you do not have to be that accurate. Ideally though you can get this total time to be exact to whatever spec the controller crystal is.
Cyfer_135
Joined Nov 14, 2024
14
XTAL frequency is 11.0592Mhz 8051 microcontroller and i have posted the code for my program just above in the thread if possible can you take a look and point out if any errors are there
Ramussons
Joined May 3, 2013
1,572
Depends on how accurate you want that 10 hours to be.
How about powering a simple AA cell wall clock and see how much it runs?
panic mode
Joined Oct 10, 2011
5,321
what if the task was to do a 10 or 100 or 1000 years? you need to think about making your designs scaleable and do incremental tests,
there is a reason we use different units of time, second, minute, hour, day, month, year..... create small delays (a second or minute) and use counter(s). you can see counter go 1,2,3... so rather than waiting, set the value to something much larger to skip fruitless waiting and focus on important things... account for things like rollover,...
