Project to produce a 10 hour time delay using 8051 microcontroller
MrAl
Joined Jun 17, 2014
13,751
XTAL frequency is 11.0592Mhz 8051 microcontroller and i have posted the code for my program just above in the thread if possible can you take a look and point out if any errors are there
What is the clock frequency that drives the timer?
Is it around 1MHz?
Cyfer_135
Joined Nov 14, 2024
14
hi, @Cyfer_135 please use the Code display option, shown on the top menu bar. Moderation
C-like:
#include <reg51.h>  // Use the correct header file for 8051
// Segment codes for 0-9 for 7-segment display (common cathode)
const unsigned char segmentCodes[10] = {
    0x3F, // 0
    0x06, // 1
    0x5B, // 2
    0x4F, // 3
    0x66, // 4
    0x6D, // 5
    0x7D, // 6
    0x07, // 7
    0x7F, // 8
    0x6F  // 9
// Timer 1 overflow delay function
void timer1Delay() {
    TH1 = 0x00;     // Set Timer 1 high byte for full count
    TL1 = 0x00;     // Set Timer 1 low byte for full count
    TF1 = 0;        // Clear overflow flag
    TR1 = 1;        // Start Timer 1
    while (TF1 == 0);  // Wait until overflow occurs
    TR1 = 0;        // Stop Timer 1
    TF1 = 0;        // Clear overflow flag again
// Function to display count on a 4-digit 7-segment display
void displayProgress(int count) {
    int digit1, digit2, digit3, digit4;
    int i, delay;
    // Extract each digit from the count
    digit1 = count % 10;            // Units place
    digit2 = (count / 10) % 10;     // Tens place
    digit3 = (count / 100) % 10;    // Hundreds place
    digit4 = (count / 1000) % 10;   // Thousands place
    // Multiplex each digit for a brief period
    for (i = 0; i < 4; i++) {
        switch (i) {
            case 0:
                P2 = segmentCodes[digit1]; // Send units digit pattern to port
                P3 = 0x01;                 // Enable units place (digit 1)
                break;
            case 1:
                P2 = segmentCodes[digit2]; // Send tens digit pattern to port
                P3 = 0x02;                 // Enable tens place (digit 2)
                break;
            case 2:
                P2 = segmentCodes[digit3]; // Send hundreds digit pattern to port
                P3 = 0x04;                 // Enable hundreds place (digit 3)
                break;
            case 3:
                P2 = segmentCodes[digit4]; // Send thousands digit pattern to port
                P3 = 0x08;                 // Enable thousands place (digit 4)
                break;
        // Brief delay to hold the display
        for (delay = 0; delay < 1000; delay++);
        P3 = 0x00;  // Turn off all digits before next iteration
void main() {
    int overflowCount = 0;      // Counts up to 1000 overflows
    int progressCounter = 0;    // Progress counter to display
    TMOD = 0x10;    // Set Timer 1 to Mode 1 (16-bit timer mode)
    while (1) {
        // Call timer delay function
        timer1Delay();
        overflowCount++;
        // Check if overflowCount reached 1000 (approximately 71.58 seconds)
        if (overflowCount >= 1000) {
            overflowCount = 0;           // Reset overflow counter
            progressCounter++;           // Increment progress counter
            displayProgress(progressCounter); // Update 7-segment display
            // If 600 increments have been reached, we’ve simulated 10 hours
            if (progressCounter >= 600) {
                progressCounter = 0;  // Reset or take any required action
                // Optionally add a signal here to indicate completion
This is the code but it's not working can anyone help me debug or give me a working code as i don't have much time in evaluation.
MrAl
Joined Jun 17, 2014
13,751
C-like:
    0x3F, // 0
    0x06, // 1
    0x5B, // 2
    0x4F, // 3
    0x66, // 4
    0x6D, // 5
    0x7D, // 6
    0x07, // 7
    0x7F, // 8
    0x6F  // 9
    int i, delay;
        switch (i) {
            case 0:
                break;
            case 1:
                break;
            case 2:
                break;
            case 3:
                break;
void main() {
    while (1) {
        timer1Delay();
        overflowCount++;
But the timer is not running at 11MHz is it?
There must be a divider between that and the timer input clock, right?
You'll have to confirm this or figure out what it is or look it up. We need to know this. You may have measured this already, so just state whatever you have measured. For example, is that 71 seconds in your code correct?
