Project: Microinverter connection
marcsmfc77
Joined Oct 5, 2016
Hey there, I am currently doing my dissertation project and part of it is using microinverters. My knowledge on microinverter set-up is limited. I'm trying to test microinverters in parallel. I was wondering if it is possible to connect 2 standard microinverters together ? if so how ? Or would it require an inverter designed for parallel connection?
Marc
marcsmfc77
Joined Oct 5, 2016
A solar micro-inverter, or simplymicroinverter, is a device used in photovoltaics that converts direct current (DC) generated by a single solar module to alternating current (AC). The output from several microinverters is combined and often fed to the electrical grid.
Hope that helps ???
