PROJECT BRIEF - Countdown Timer
capturefilms
Joined Nov 19, 2019
13
I am looking for someone to build a countdown timer. It is to be used as a prop in a film.
I don't need the housing, just the electronic components, I have no experience with this kind of thing, so I am looking to commission someone to make it.
I need three components, that are programmable , hours (3 digits), mins (2 digits), seconds (2 digits), (see attached still). I do not need the wording of Hours, mins, Secs to be made, these will be part of the housing.
I have seen single, double and treble digit LED units (see attached still) and was hoping they could be made from something like this.
It will be placed in a custom housing, approximately 2.5 inches x 6 inches. any wires/components/power supplies can be easily hidden.
If anyone would like the challenge of building it or can point in me in the direction of someone than can that would be very much appropriated.
Many thanks in advance
JohnInTX
Joined Jun 26, 2012
4,787
Be aware that if the display is multiplexed you can have have strobing in the image when you film it unless the refresh rate is considerably higher than the frame rate.
Ya’akov
Joined Jan 27, 2019
10,235
Well, it's not a particularly difficult project so perhaps someone will want to take it on. It will still be costly if you want to done right as a one off.
JohnInTX
Joined Jun 26, 2012
4,787
A good choice for a display would be something like LTM-8522. These are old but still available. They use a simple serial input to drive the segments directly, no multiplexing. You could daisy chain 3 x 3 digit units and just mask off the two unused ones.
capturefilms
Joined Nov 19, 2019
13
Thanks john, but this is a foreign language to me, I wouldn't know where to start. I'm hoping to find someone that I can work with to build it for me from scratch
dl324
Joined Mar 30, 2015
18,326
What are your constraints on solution space? Personally, I'd probably use an Arduino Uno for something like that.
Just keep the multiplex rate high enough that you won't see flicker when it's filmed. Maybe 1kHz or so.
capturefilms
Joined Nov 19, 2019
13
Sorry mate, I have no idea what this means. As I said, I'm hoping to find someone that could build it for me.
Bernard
Joined Aug 7, 2008
5,784
What power is available, AC 50 HZ, 60 HZ DC ?
Where are you?
Are you supplying the display ? How is the initial time delivered ?
dl324
Joined Mar 30, 2015
18,326
Hate to be the one to burst your bubble, no one here works for free. We give free assistance as a community service, but we don't work for free.
capturefilms
Joined Nov 19, 2019
13
Where are you?
I can supply any power required to the unit. The car will be static whilst being filmed.
I'm in the UK.
I will buy all the necessary components and ship them wherever needed.
capturefilms
Joined Nov 19, 2019
13
I haven't asked anyone to work for free. if you read my post again....you'll see that a) I'm offering to commission someone to make the project and b) I know nothing about this stuff.
That's why I'm here. Cheers.
dl324
Joined Mar 30, 2015
18,326
When an engineer designs a product, they assume responsibility for product liability. I wouldn't do piece work for less than $10,000 plus a per diem rate of $2000.
I'll help you design it for free...
capturefilms
Joined Nov 19, 2019
13
I don't understand. Are you offering to help design it for free, but you want $2,000 a day to build it?
Bernard
Joined Aug 7, 2008
5,784
How is the initial time delivered, or is it just a random number ?
I made a digital clock in 1972 with TTL logic but that was 47 years ago & I hate shipping overseas.
capturefilms
Joined Nov 19, 2019
13
It shows different times of a 7 days countdown, which we must be able to programme into the timer.
dl324
Joined Mar 30, 2015
18,326
Yes. If I help you design it, I have no product liability responsibility and I can walk away from it at any time. I don't have to take your written and spoken requirements and turn that in to a specification for what you really want.
Could probably bang out the Arduino code in less than a day and design the hardware in a few hours (at most). If I designed it, I need to spend time understanding your requirements, writing a project proposal, having it approved by my attorney, and iterate until the spec is correct. Then I need to design and build according to your schedule. Even if you want to build it, I'd need to build it myself first to make sure it met specifications.
I found some displays here, but none are exactly what you want and they're all bigger than 2.5"x6".
