project box
34,809
There is no project box available that I know of which will have a square cutout for that USB-B connector. You will have to cut the hole yourself. Choose plastic or aluminum. You will need a round and square file.
GopherT
Joined Nov 23, 2012
8,009
Check shapeways.com.
People design 3d objects in CAD programs then dsubmit them to shapeways website. You can order one and shapeways.com will "print" it in their 3D equipment for you and pay the designer a commission.
See attached iPhone case. You can search your project boards name. It is amazing the projects that are available. Cost is buy the gram. Parts are light and strong but not full density so it is rather cheap for a short run (less than $30 for the geared iPhone case shown.
http://www.shapeways.com/model/997471/iphone-gear-case-for-shapeways.html?li=productBox-search
Also, Raspberry Pi case
http://www.shapeways.com/model/486999/raspberry-pi-case-1-0.html?li=productBox-search
Joined Dec 26, 2008
199
Well I found out the size of the board is 2.2" x 2.7" x 0.4" if that helps.
Way smaller then it looked in the pictures
